Volunteer Wanted! Help needed! N97 owner needed.
9 replies · 6,549 views · Started 08 February 2010
As you may have seen in previous thread I have an N97 that refuses the charge!
In order to try to fix the problem, I need to have access to battery with some charge. The 2 batteries I have are completely flat!
If I send somebody 2 batteries, with a return envelope etc, would someone be able to charge them for me, and then post them back?
Many thanks
Matthew
Why not buy a desktop charger from ebay. They come with a spare battery, and you will get it before you receive anything you send out to volunteers. I have one and it works great, it also has a usb port on the top if you want to charge both at the same time. Hope this helps.
aquamally wrote:Why not buy a desktop charger from ebay. They come with a spare battery, and you will get it before you receive anything you send out to volunteers. I have one and it works great, it also has a usb port on the top if you want to charge both at the same time. Hope this helps.
Smart idea - will have a look this evening - ebay is blocked from the office.
Matthew
Do you have a link for what you bought?
I can only find a desktop charger, but no spare battery included.
dog-man
dog-man wrote:Do you have a link for what you bought?
This one might do the trick:
http://cgi.ebay.co.uk/BP-4L-Battery-UK-AC-MAINS-DESKTOP-Charger-FOR-NOKIA-N97_W0QQitemZ190367524751QQcmdZViewItemQQptZUK_MobilePhones_MobilePhoneAccessories_MobilePhoneChargers?hash=item2c52c9e78f
[EDIT] Just had another look and have found that this item is in Hong Kong, so it'd probably take at least a week to get to you. All the UK sellers seem to just sell the chargers without batteries. Sorry 😞
Just ordered one.
I can't believe that the battery will be very good at that price though.
dog-man
Murphy's law strikes again!
The charger arrived yesterday, but on opening discovered that the seller has sent the wrong one....
Now awaiting a response from the seller.
Oh well......
Matthew
I received this charger and battery yesterday and am now using the battery after charging overnight.
Despite it saying it was to come from Hong Kong, it actually came from Frankfurt in Germany. The whole thing and battery looks very, very cheaply made but seems to be working ok.
dog-man
zxon wrote:This one might do the trick:
