I've suddently had problems with sending sms when the country code is included in the telephonenumber.
At the same time, when I get incomming calls it don't show who in my contact list who is calling, only the number.
Anyone?
Anyone?
this problem needs closer look.
Are you in another country or areacode ?
For problem #2 - did you create your contact with country code-areacode or simply the number ? If the callerid does not match with the telephone number in the contact, it will display the number.
...guess it wasn't the countrycodes afterall...suddenly I couldn't send sms at all. So I had to do a "major reset" :cry:
I had problem with the phonebook. When I transferred my number to the P800 it remove the "+" sign from the number. I normally store numbers with the "+" sign followed by the country code. When I tried to call gave me an invalid number message.
[quote="i-ball"]I had problem with the phonebook. When I transferred my number to the P800 it remove the "+" sign from the number. I normally store numbers with the "+" sign followed by the country code. When I tried to call gave me an invalid number message.[/quote]
I always use "+" on my contacts. The sync. program faithfully have transferred all my contacts with "+" followed by country code.
Give examples ?
