Touch Screen QWERTY keyboard
9 replies · 10,990 views · Started 10 February 2010
Hi guys, havent been on here for yonks. just got my N97, mixed opinions. I really loved my n95/96 but this is taking time to grow on me although im sure it will 😊
Anyways, as much as i love the keyboard, i cant get used to texting landscape. I'd much prefer a QWERTY keyboard on screen like the iphone. is there any app which does this? Many thanks
Stezo2k wrote:Hi guys, havent been on here for yonks. just got my N97, mixed opinions. I really loved my n95/96 but this is taking time to grow on me although im sure it will 😊
If you need an on-screen keyboard in portrait mode for when you're browsing the web, there's one on Opera Mobile.
Other than that, I don't think there is one...
I'd advise you to get used to it - it's much better than texting in portrait mode, using the physical keyboard is great IMHO, much better than any on screen virtual keyboard.
try this one. Never tried it myself but i think its what ur looking for. Let me know if its any good.
http://www.i-symbian.com/dayhand-keyboard-alternative-text-input-for-symbian1/
just remembered an another app. It's called SlideIT. Tried it once. Very cool virtual keyboard on both landscape and portrait mode. But there was one problem. It started typing different letters when i used the real keyboard. Dont know if u can turn it off on landscape mode. The app was a beta version when i tried it so they might have fixet the problem. And u can try it for free. SlideIT. Google it. And some good clips on youtube about it.
fadi_k wrote:try this one. Never tried it myself but i think its what ur looking for. Let me know if its any good.
Hey, nice find fadi_k!
I installed it on my N97 this morning and it's so much nicer to use a virtual keyboard than the virtual numberpad Nokia make us use. It took a short while to set up though because all the options in the menus appear as squares, probably because they're written in Japanese or something and my phone doesn't have that language built in.
It works in both portrait and landscape mode. I don't think I'll find myself using the landscape one as I can just open the phone and use the physical keyboard instead, but the portrait one works wonders when I'm forced to use just one hand.
I would advise everyone give this a go. It'll need signing though. If you're going to try it, go for the 17r4 version instead of 19r4. The latter wouldn't install on my phone for some reason.
Again, nice find! :icon14:
[EDIT] Here's where SlideIT is - http://www.dasur.co.il/index.php - Looks interesting. I might give it a go later.
Ahh looks like I spoke too soon. Having the app enabled makes the physical keyboard print the wrong characters. Then again it doesn't say on the site that it was tested on an N97. Hopefully there'll be a new version that supports it fully.
zxon wrote:Having the app enabled makes the physical keyboard print the wrong characters.
witch app u talking about? Dayhand or SlideIT?
I know that Slideit makes the real keyboard go nuts but havent tried dayhand.
Yes, there should be a way to turn it off on landscape mode.
fadi_k wrote:witch app u talking about? Dayhand or SlideIT?
Sorry I was referring to DayHand. I'm still exploring the menus to see if I can fix the problem but it's not looking good. Don't get me wrong: the horizontal keyboard is quite nice to use but nothing compaired to the physical keyboard.
SlideIT is now on OVI with a new version
http://store.ovi.com/content/24305?clickSource=search
nice Video for my Russain friends :
http://www.youtube.com/watch?v=x9-PCFT0Bos
