is it possible to convert 3gp to avi file? what program? it would be nice to watch these video's with windows mediaplayer..
converting 3gp to avi?
As far as I know you can only play them with the nokia media player which will also view wmb and amr audio files
nobody? 😞
even googles got no answer 😃 i searched "convert 3gp to avi" - no results found
use Philips Platform4 PC Player http://www.digitalnetworks.philips.com/InformationCenter/Global/FArticleSummary.asp?lNodeId=764&channel=764&channelId if you dont like the Nokia Multimedia player
Doesn't it automatically convert it when you transfer between PHONE and PC? I know sending an AVI automatically converts it to .3GP
Nope it doesn't convert. Maybe that is why Nokia released a free Multimedia player for PC
[quote="daniatt"]use Philips Platform4 PC Player http://www.digitalnetworks.philips.com/InformationCenter/Global/FArticleSummary.asp?lNodeId=764&channel=764&channelId if you dont like the Nokia Multimedia player[/quote]
i want to convert 3gp to avi because if i send the video by email to my friend he has to install nokia multimedia player! it would be much easier if he could just use windows mediaplayer..
Yep.. its much better if we can view 3gp using windows media player and it will not be a trouble for our friends to download additional 3rd party player but WMP cant simply play it 😞
Anyone work out how to do this yet? It's bizarre that I can't convert the little images for use in other applications, for example if I wanted to embed them in a shockwave program or something.
Anyone?
Apple is developing an application which can convert 3GP to MPEG4.
Where can you download the nokia media player from?
(I have already tried searching and cannot see it)
I have the phillips player - but when I play a *.3gp file I can hear the sound but can see no picture.
Thanks for the help
[quote="Will137"]Where can you download the nokia media player from? [/quote]
Here is the link:
http://www.nokia.com/nokia/0,5184,5371,00.html
I know this is a very cheap hack, but you can use a screen grabber program like Hypersnap, select the region you want to capture, and then you can capture it as a movie...it's some time ago that i worked with this program, but i think it's possible
I want to convert .3gp to somthing. I can transform to somthing as well. I can transfer pics and video via Bluetooh to my iPAQ and then to my laptop but carnt play the video 😞. plz someone make a solution to this 😊
Troy
DOES the phone autoatically convert ANY AVI to 3GP when being sent TOO the phone?
try this info....
http://blog.chris.de/archives/22_Nokias_3gp_Files.html
and
http://sourceforge.net/projects/ffmpeg/ 😃
i can play .3gp files on my comp.. i juz downloaded da phillips platform4 player n it works like a charm 😃
[quote="super g"]try this info....
and
http://sourceforge.net/projects/ffmpeg/ 😃[/quote]
That's great, but both MPlayer and FFMpeg are distributed as source code.
You need someone to build them for Windows (or whatever platfotm you use). Anyone?
This site has step by step instructions on how to convert .3gp to .avi! :Fade-color
:bday:
I've developed a little free app capable
of grabbing nokia multimedia player images during the play
and create nomal uncompressed avi file.
(can be used wherever you want in the screen)
It's a first simple simple beta software, I've used bruteforce image
clipping to create the avi, but results are good..
Well, hope you'll enjoy this file..
I'am preparing another advanced version to choose the
codec ,etc...
Post here whatever for want.. about this..
Miquel Taule
spain
check this out http://www.mitsoftware.com/akiles
Akiles free software
[quote="Anonymous"][quote="super g"]try this info....
and
You need someone to build them for Windows (or whatever platfotm you use). Anyone?[/quote]
I tried using MPlayer, with appropraitely modifying codec.conf as mentioned above, but I continue to get error which is as follows
Playing abc.3gp
MOV: FIle-Type unknown Major-Brand: 3gp4
MOV: missing header (moov/cmov) chunk! Maybe broken file ....
Falling back on trying to parse playlist abc.3gp...
Sorry this file format is not recognized/supported
[quote="Korsakov"]This site has step by step instructions on how to convert .3gp to .avi! :Fade-color
http://www.angelfire.com/pro/nokia3650[/quote]
Thankz dud, you made my day! 😃 :angel: 8) 😃
i've been having problems converting .3gp to .avi using your software 3gptoavi 2.0. i keep getting an error after it says "working..."
here's the convert error i get when i click on details:
CONVERT caused an invalid page fault in
module CONVERT.EXE at 0197:004020e6.
Registers:
EAX=0064f794 CS=0197 EIP=004020e6 EFLGS=00010202
EBX=0064f794 SS=019f ESP=0064f730 EBP=0064f740
ECX=00000004 DS=019f ESI=00000000 FS=78a7
EDX=00000001 ES=019f EDI=00000004 GS=0000
Bytes at CS:EIP:
66 f7 46 0c 0c 01 74 08 8b 46 18 89 45 14 eb 0c
Stack dump:
00880d7a 00000000 00000000 00000004 00000000 00401251 00000004 00000001 00000004 00000000 0064f7f0 0040d0fc 0064f7f0 0040d100 00880d7a 0040d108
please help!! :cry:
[quote="Miquel Taule"]:bday:
codec ,etc...
Miquel Taule
spain
Akiles free software[/quote]
[quote="meitsi"]is it possible to convert 3gp to avi file? what program? it would be nice to watch these video's with windows mediaplayer..[/quote]
try this link...
http://www.angelfire.com/pro/nokia3650/3gp_to_avi.html
http://www.apple.com/quicktime/download/3gpp/ :bday:
use Quicktime to play them you mook.
:-? well nope....
but i am finding a website to download 3gp files to my handphone...
oh ya....
hi ya ppl
my name is Tessy
[quote="fearce"]DOES the phone autoatically convert ANY AVI to 3GP when being sent TOO the phone?[/quote]
yes (u need to use PC Suite to transfer it though).
think you ... 😉
[quote="guest"][quote="Korsakov"]This site has step by step instructions on how to convert .3gp to .avi! :Fade-color
Thankz dud, you made my day! 😃 :angel: 8) 😃[/quote]
yeah, works perfectly!
+chris
