HI!...
I installed the new Wildskinz 1.3...
Now work much better, more stable, no errors ... more fast...
and the most important thing... it�s compatible with most of the apps,
and... if is not compatible, you can disable with the new Disable Skin App List ... cool! 8)
The only app that i mark on my disable list is Oplayo App... so i enter to Oplayo and the skin is auto turned off.... when i quit automatic turn it on again, without problem... and very quick...
all the rest work fine... 😃
Now i can use my skins again 😃
cya!
and Thanks Wild Palm for this good upgrade
There is a bug which makes your keypad get stuck on number mode. I have seen a few guys complaining about it here. To cure this, you have to reinstall Wildskins 2, run it then uninstall it to return to alpha mode. Has anyone had this experience?
im not installing wild skinz again.. never! 😃
works really good with me..
i like that one a lot 😊
never had any wildskin-problem, but maybe because i paied for it? 😃
Can anyone post or tell me where can i get skins for wildskinz? i'm currently using it coz i'm bored looking at the white background. thanks in advance for anyone posting thier skins!😃
