After installing the above, I set it up as I wanted it, sorting feeds out etc and I was very happy with the app.
The next day it is gone!!!! 😮
Anyone have any ideas.
Now I cant even download the app again from anywhere!
Any advice?
Any advice?
When you can find Snaptu , which is a JAVA app , in Application Manager , but the Icon is gone ?
Use Nokia MidletRestorer to retrieve the Icon :
http://europe.nokia.com/support/product-support/nokia-n95-8gb/software
Another workaround is deleting Snaptu from Applications Manager and then re-install .
😊 Regards jApi NL
