I just got this 5800 nav edition and I love it, except for this annoying feature that started happening to me. Every time I power the phone on after its turned off it asks me if I want to allow a connection to the internet and if I say yes it starts the email setup wizard. I have one email setup already and do not need another one. How do you keep this thing from starting up?
Email Setup Wizard starts automatically after turning phone on
I found one way to fix this issue and that is to uninstall the Nokia Email application from the application manager menu on your phone.
This fixed the problem but then there is no email app to use which stinks.
I then added the email application from the computer using a USB interface and the Nokia Ovi Suite. I had it check for updates while my phone was plugged in and set to the PC Suite Mode and installed it from the PC. Now I have email and it doesn't startup when I turn my phone on after its powered off.
I don't know if this will work for anyone else but I figured it might help to pass the info along.
I had the same problem as well. I restarted the phone and added mailbox that was already there, tahn restarted the phone again, deleted that account and problem was solved.
