I am very happy with ovi nav but I ran into a problem with usability. I don't know if its the app or me.
I found that I really had to look around to enter a destination street address. The search would find anything close to the address and I finally was able to enter it thru history. Am I missing something here?
Is it just that the app assumes that if the internet search fails the location doesn't exist? It did work fine when I entered it thru history.
Should I guess there will be no way for me to enter actual GPS coordinates?
TIA, Jeff
Do you have the maps preloaded? I found that searching, for example, 'Station Street, Nottingham' worked perfectly.
jmurch wrote:I am very happy with ovi nav but I ran into a problem with usability. I don't know if its the app or me.I found that I really had to look around to enter a destination street address. The search would find anything close to the address and I finally was able to enter it thru history. Am I missing something here?
TIA, Jeff
Which version of Ovi Maps are you using?
version is 3.03 and yes the maps are stored locally.
Jeff
I have found if online search does not find anything i have to go into settings and internet set it to offline then do the search again then it usually finds it.
