Windows live Messenger
10 replies · 10,398 views · Started 24 February 2010
hi. i used the original windows live messenger daily on my n97. but yesterday i formatted everything and updated to 2.1 and i can't find an appropriate installer for wlm. can someone help me on this? the installer i've found keeps telling me at the end of the installation process that "installation cancelled"
Micky! wrote:Yes, is is indeed the official file, extracted from N97.
Confirmed! But it's kinda buggy that contact list... the kinetic scroll and the next/forward contact arrows don't work pretty well! And the list display is kinda messy... :P
i can't install it. just at the end of the installation, it says installation cancelled. any help?
lp4u wrote:i can't install it. just at the end of the installation, it says installation cancelled. any help?
Sounds to me like you could be being impatient & pressing keys, thus inadvertently cancelling the install.
Installation takes aaaaaaages & at one point looks like it's done when it isn't.
Just bear with it & it should finish.
actually i send the setp\up to my phone via BT and it did not install. so i use nokia installer and it worked. don't know what he problem was 😞
