Install language in Nokia N97 Mini
3 replies · 31,260 views · Started 27 February 2010
Hi, I need to install Portuguese language in a Nokia N97 Mini bought in the UK. Can you please tell me all the steps I have to take to do that?
Thanks a lot
MagaPatalogica wrote:Hi, I need to install Portuguese language in a Nokia N97 Mini bought in the UK. Can you please tell me all the steps I have to take to do that?
Thanks a lot
You will need to "debrand" your handset (and risk voiding your warranty) to do this.
Basically, you are changing your phones product code to one that contains the language pack you require. In your case, depending on the colour of your phone, it will be either... 0592413 for a black mini or 0595418 for a white one. See here for product code list:-
http://www.nokiausers.net/forum/nokia-n97/31541-n97-mini-product-codes.html
You now need to follow the step-by-step instructions here:-
http://nokia.nigelcoldwell.co.uk/firmware.htm
Good luck!
Thank you very much... It worked, although the information with the day of the week disappeared and the word "OPTIONS" in the desktop still appears in English.
Thank you so much anyway.
Hello, I need help.
I just bought a Nokia N97 mini and I have changed the product code. I need to view Chinese on my phone. But, the problem is even though I have changed the product code but there is nothing change on my phone. Please tell me what I need to do. Thank you very much
