HELP! - 3650 Problem.
2 replies · 1,874 views · Started 19 March 2003
I got the 3650 yesterday (Tuesday) Very impressed!
However, I have a small problem :
using Nokia PC-Suite for the 3650..... I transfered some Midi Files across to the phone memory directly from the CD-ROM..... Now, these files are 'READ-ONLY' and Now I cant delete them,move them.... They play Fine.... I have tried overwriting the files with same named ones but with archive properties enabled.... But the 3650's having none of it!
its not the end of the world if there is no solution as they only total 250kb insize...... so I can live with it...... But if there is away to get them off I would be eternaly grateful.
Thanks in advance,
Paul (UK) - A Pround 3650 Owner!
Get yourself one of the file manager applications - either for use directly on your phone or a PC one - you may even be able to do it in Nokia Suite? Never tried.
But basically you want to look at the file 'properties' and you will see that 'read only' is ticked. Untick it and your back in business 😊
Next time if copying from a CD - put them on your desktop first then right click the file go to properties and uncheck 'read only' before putting them on your phone.
Click the big banner above this Forum and you'll be taken to a site where you can get filemanager - the demo will probably be sufficiant, but once you've played with it I'm sure you'll want to buy it!
Best 😊
Will
