Is rotation by choice possible?
4 replies · 3,682 views · Started 04 March 2010
When I talk on the phone I tend to turn it semi-sideways because of the ear and mouth location. N97 likes to rotate screen when I do that and when the call is over - I get agitated since I am holding the phone in vertical position and want to go on using it. I know this is quite minor, but is possible to turn off auto-rotate BUT allow rotation by choice? I want it to rate when I press some button or some app that does it. Any ideas?
You can go to settings>phone>sensor settings>turning control, un-check auto-rotate display.
The screen will not rotate unless you open the keyboard. I think that is what you want.
Cheers.
that's available too, but pretty much sucks when the screen needs to be rotated without the keyboard open all the time
Thanks for that ajeet, that was one thing that used to annoy me about my phone. Now I dont have to shake it to get it back to normal. 😃
Cheers Robski
