I dont know if its the right place to post this topic or developers, but... as I am not sure, ill try it here...
I've got a huge list of apps and things that should be corrected in 7650 phones (from my point of view) Maybe Nokia developers should have a look at all these suggestions. U know if there's a way to send this kind of mails to nokia developers?
- T9, working for searching Contacts and also for the address of msg, mms and emails
- Mute profile. it does not work with all programs, such as java apps, games or even hantro videorecorder... What a problem!
- Favorites, it should work with all programs, it should work as a way of creating shortcuts for ALL kind of programs, even java apps
- Subfolders. Why cant we create folders inside other folders??
- Wallpapers. They're cool, but it would be nice they worked at full screen mode, like other nokia models 7210, 7250, 6610...
- Java shotcuts. Its is terrible to go through the whole menu in order to reach the apps installed...
- Key combination. As far as I know, it's impossible to use 2 keys at the same time and this is terrible to play with some games (goboy), I cant jump diagonally! It would also be better to take that finger-pain-maker joystick away and introduce one like the Ngage or 3650, with 8 directions movement possibility.
- MMS. They cant be re-sent... snif snif (or is it only my phone??)
- Compressors. they dont work with 2 mixed programs such as MGS + Karts o updates. They usually get corrupted and dont work any more
- Some extras, well what we all know...
MP3,
Memory cards
A bit smaller size of the phone (snif snif... I loved my tiny old 8210)
All showed, no necessity of opening it , its a mess...
Flash cam
More picture quality , it isnt very good...
USB port, please!!! IR and bluetooth only give problems to many users!!!! Thay dont work properly in many computers!
AND, a real bame goy emulator that works properly, pleeeeeease
By the way, does anyone know how to show these ideas to someone from nokia?? Are these ideas read by developers or are only for us, fanatic users?
