Hello All,
I've got loads Of Java Games for the 7650 (CDRom Brought from Ebay)
They consist of '.jad & .jar files' (Mostly Anyway) Using Nokia PC Suite for the 3650.. how do I get these Games into the phone...... (3650)
And whilst on the subject of games....... Alot of these symbian games (7650) that I've got wont install on the 3650... I get the report that they are not compatiable with my phone (3650)... Is there anyway around this ?
Thnx,
Paul (UK)
Send them using infrared or BT or email or MMS attachment if no PC Suite. If there's PC Suite.. sending with PC Suite is also ok and it will install it for you.
That means the application is not compatible. The only way to make it work is the author of the games or applications will debug them to make it work for 3650. If you purchased the games and applications from the developers, you can send them an e-mail to ask on whether they are working on it to work with 3650 or if there is an upgrade version to be able to work with 3650.
