Does anyone having Infra-Red Problems when......
6 replies · 1,537 views · Started 19 March 2003
When you tries to Send pictures/sound clips from 7650 to 6610/6110,you will receive a error Sending Failed,both handphones already enabled infrared.....is this a *bug* between 7650 to 6xxx series phones?but when i try to send phonebook contacts between this 2 phones,no problem.....only pictures and other files ? 😞
What kind of pictures are you trying to send, the 6xxx series cant display things like photo's only picture messages, (those cra**y old things of birthday cakes and stuff)
The 6xxx series probebly has no idea what type of file it is and therefore doesnt know what to do with it, so error's out
As far as I am aware the 6610 can only recieve images and ringtones via PC suite.
It does support MMS so photo's are acceptable.
Bob
Yup it is 6610,tried on 2 6610's and still got the error msg,.....oh yea,is it because i took high quality photos and 6610 cant view high quality pics ? 😮 also i tried to send wav files,also got error msg (using FExplorer)
not sure...is my friend's 6610,i want to know if transfering can be done between 7650 to 6610
As I said earlier I have tried it from both a 7650 and a laptop that works perfectly with transfer to a 7650. The 6610 will not accept the files.
After reading the manual it sais that you can only send files to it via PC Suite.
Sorry.
Bob
