Do you get this too? Mobbler randomly shuts down my entire N97 and I tried that on each version of firmware and Mobbler...
Mobbler shuts down my N97 with any firmware...
i didnt get that on v11 which was on my N97 when i got it, seems to be pretty much the same on v21. I love this app btw
bump to this issue!
Mobbler requires about 9-10MB of RAM just to run so if you have not got this or, have an app (like Nokia Messaging) that makes a call on your RAM whilst Mobbler is playing, this could cause the cut-out.
Another factor could be your wi-fi settings cutting out the connection.
Make sure you are not connected to wi-fi and then:-
Menu > Settings > Connectivity > WLAN > Options > Settings > Options > Advanced settings > *Ignore warning* > Automatic configuration (set to disabled) > Power saving (set to disabled)
