Some problem please help me!
2 replies · 1,518 views · Started 19 March 2003
Hi there,
I have bought a second hand 9210i in england but I'm italian.
Thus, my problem is that my 9210i is an english version.
I read in a topic, that there are the sis files to change te language
version.
I downloaded it, but there is a problem: the sis file is for v. 5.34 i have a
v. 3.18. My problem is, how can I upload the version number?
I have just a PC-cable, nothing else. And afterwards how can I install
the sis file? Shall I have a Pc software or something else? And if so,
where can i find it?
Thank you.
all software can be found at the nokia.com site
you can go to a service center and they can change your firmware and language.
you can also try localisation from PsiLoc.
Use PC Suite which is a software to connect through the cable from your desktop pc to yur 9210i. also from nokia.com
but the best thing is to leave it in English. Changing the language can give problems.
Thank you!!
My problem is that I can't go to a service center because it's too far, and therefore I have to make all by myself.
