As per the title is there a way of doing this? I tend to use the calculator a lot and its a PITA to keep going into office to use it.
Cheers in advance
Robski
Cheers in advance
Robski
ROBSKI wrote:As per the title is there a way of doing this? I tend to use the calculator a lot and its a PITA to keep going into office to use it.Cheers in advance
Robski
Yep there sure is....
From the home screen go to "options" - "Edit Content" - then choose one of the two widgets that has 4 shortcuts inside it, then choose "settings" and replace one of the shortcuts with the calculator app. Hit exit, then done and you're done! (the downside of this is that you'll have to replace one of the existing shortcuts with the calculator, but I'm sure there's something that you may not use as regularly as the calc.)
Cheers Mate your a champion...😃
Pitty were going to beat you at the cricket today...😊
Thanks again,
Robski
No probs mate, always happy to help where I can!
Cricket? Black Caps? Yeah, I do live in Auckland, but moved here 5 years ago from London! Still, I'd rather the Kiwis win than the Aussies... I get enough stick for being British as it is without upsetting the locals!!!
