can any of you experts solve why my umts network option has dissapeared i use to use it at home for my sky sports coverage as 3g signal low in my area then bang its gone but were.
umts missing
I suggest doing a manual scan for networks - you will probably see other operators 3G networks show up to prove the phone is ok. Then it's on to your (completely useless and unhelpful) operators helpdesk to report the problem. Note I don't know who your operator is - but from experience they are all useless.
macmyles wrote:can any of you experts solve why my umts network option has dissapeared i use to use it at home for my sky sports coverage as 3g signal low in my area then bang its gone but were.
thanks for replying rang vodaphone uptoday and they cant work it out so sendin me new phone monday., the hard reset didnt work nor did the the roaming search.
