http://www.nokia.com/cda1/0,1080,2019,00.html
Nokia Video Recorder for 7650 published
Thanks for the info 😃
At Last!!
Nice one! 😊
Is it any different than the 3650 one, or shall I just stick with that one??
And it works!!
Yesss!!
Yes Eckrall - get this one, it allows videos to be played directly from your inbox!!
Thanks Nokia!
Will
Can anyone tell the size of it on the phone? Preferably the real size from sDoubler... 😃
As my phone is really full at the time 😃 cant install it now.
App Manager has it at 420kb
Yeah, thanks, but thats always wrong 😃
Okay, had a fiddle with this, its EXCELLENT! Works beautifully, much better than that ole T-Mobile cr*p!
[quote="JyriK"]Can anyone tell the size of it on the phone? Preferably the real size from sDoubler... 😃
As my phone is really full at the time 😃 cant install it now.[/quote]
Jyrik, With Sdoubler it's 109K (compressed). That's 1k more than the 3650 recorder. Uncompressed = 279kb
Whit stacker3.0 its 112kb DOH! But still Stacker is the best! 😉
[quote="Doc"]Jyrik, With Sdoubler it's 109K (compressed). That's 1k more than the 3650 recorder. Uncompressed = 279kb[/quote]
Thanks a bunch 😃
[quote="Urpo"]Whit stacker3.0 its 112kb DOH! But still Stacker is the best! 😉[/quote]
Yeah I can see that 😃
does it have audio?
[quote="ashby"]does it have audio?[/quote]
Yes, it has!
my can't seem to play videos directly from from the inbox. anyone can help?
does this one have a limit for recording? or is it exactly hantro 3.4 but with a facility to play in the inbox?
Asfar as I can see the only difference is the inbox playing facility. Also my clips are not longer than 9 seconds with it. Shame.
If you could have it with Size,quality,resolution and sound options (like Hipcam) it would be the best video software. Hip cam always has worse video quality than hantro on my phone, no matter what the settings I use. Also the sound is badly out of synch too.
thanks for nokia for releasing this software! its much better than the video clip alone.
This video program records 3gp so nokia must release some sort of profram that allows us to play the vids on pc. does any one know about it??
Yes there sure is😊
http://www.nokia.com/NokiaHome/0,5184,5377,00.html?applicationId=314&disclaimerAppID=1&disclaimerId=9&fileId=3432&parentId=5371&languageId=1
Also if you send a file from the new recorder via MMS or Email you will notice Nokia includes a link for the recipient to download the PC player too.
Nice Nokia 😉
Best
Will
I wonder if this Video Recorder has compatibility with some versions that use *.mp4 instead of *.3gp. I mean if I send a video as an MMS would it play on the phone with a different Video Recorder program/version/file type?
Currently I see a Philips version, many Hantro versions, the Globe Video (Philippines) which is also Hantro and this Nokia Video Recorder that is also Hantro. So many.
