Hi there.
I have a N97mini for some time and i am very pleased with it.
I have a couple of problems though. A few days ago it started taking like 10sec to send text messages. It says "sending message" and i can't do anything meanwhile. I remeber that when i bought it that this would take about 1sec.
What could have happened? I have the last firmware release.
For the second problem, lol. I have defined a tone for received calls and sometimes it just uses the original nokia tone!!! Anyone knows why?
Thanks in advance.
Antonio
Re the messages: I did notice on my N97 that once the inbox got quite full, it started to respond slowly ( full by having 300+ messages in there ) , so deleted the whole lot them, and it went back to 'normal' speed of loading and sending messages.
Have you also changed where you store the messages? I have them stored on the E drive, not on the C Drive
Re the Ring Tone. This was quite a common problem with older FW on the big N97, and not sure if there is a way around it. Ian - one of the regular posters on here - did send me a suggestion for a cure so if you want, I can forward it to you, but it's quite long winded.
Have you noticed when the phone defaults to the Nokia Ring Tone - is it when you have just re-booted the phone?
Angelyzer,
I have a mini and I really like it but i too have the problem with the assigned ringtone reverting for no reason to the default Nokia tone.
Jeff
nottmbantam wrote:Re the messages: I did notice on my N97 that once the inbox got quite full, it started to respond slowly ( full by having 300+ messages in there ) , so deleted the whole lot them, and it went back to 'normal' speed of loading and sending messages.Have you also changed where you store the messages? I have them stored on the E drive, not on the C Drive
Thanks for the reply nottmbantam.
I've deleted all the messages and now it works perfectly. I had about 50 messages though and i'm afraid i can't keep nothing near 300 messages or so. It's a shame. I had them stored on the E drive and still do. Hope they can fix this problem soon.
About the Ring tone, i never noticed if it occurs after a re-boot but i'll try it. If u can suggest how to solve it, i appreciate it.
Regards
I'll have a look through my PM's, and forward you what Ian had posted me, it may help. The ring tone fault is quite a common problem on older FW versions, the phone just randomly defaults to the Nokia tone very now and again, though to be honest, it hasn't happened to me for a while, maybe FW 21 has sorted that.
It's OK Notty... I've put my head on the block and posted my theories and work-arounds for the N97 defaulting to that bl**dy Nokia ringtone. See here:-
http://www.allaboutsymbian.com/forum//forum/thread/93639/
I have to confess to sheer laziness and haven't tried out your theory, but have made good use of it and PM'd it to Angelyzer ! - hope it does the trick for him.
Cheers.
Thank u both for ur help.
I've done the trick and so far so good 😊
Hope they fix the bug soon though, so that i don't have to downsize every songs before i use them as ring tones.
Cheers
nottmbantam wrote:I'll have a look through my PM's, and forward you what Ian had posted me, it may help. The ring tone fault is quite a common problem on older FW versions, the phone just randomly defaults to the Nokia tone very now and again, though to be honest, it hasn't happened to me for a while, maybe FW 21 has sorted that.
If you are feeling up to it, could you also please forward that message to me? It is a very irritating problem on my N97 as that original tone is one of those noises that just gets to me, like nails scratching down a chalkboard!
