Pleas help!!! And if i run/download a zip file i can nothing instal in zipman?!?
Can not run telanswer or camerafx!
Willbrody i iave inst. Wildkinzs! And the cameFX but thes no run! Its giv me a error!
Hi mate.
Zipman is only for I think text files images and ringtones.
I don't think it will open a PC zipped up .sis file.
Wildskins and CameraFX I have not tried on my 3650 but worked fine on my 7650.
You may find that some applications will not run if installed to the MMC, did you install them to the MMC, if so uninstall them and reinstall to the phones memory.
Hope that helps
Best 😊
Will.
Ok if i have enabled wildkins on answer thos not run! But now is good! Mayby i have a problem whit camfx! Must i delet the old cam????
Perhaps CameraFX does not work well on the 3650, ask WildPalm if it works with 3650?
I think it's a 7650 application.
Best
Will
I have now download the new goboy but is zip! How i can instal now?
CameraFX version 1.3 works well with N3650. I've installed it in the MMC and it is functioning well.
Just an advise: If you will install CameraFX in the MMC, verify that the Images is using MMC as the memory in use so that all images that was captured by built-in camera and CameraFX will be saved in the MMC.
Nice but not for me. Who you have download this vers.?
Get it from www.wildpalm.co.uk send the .sis file to your phone using infrared, bluetooth or attached it as an e-mail
No you dont and cannot remove the built-in camera software
