ive just installed all the software required for this application to work. when i go through the extras menu and select AbbrInHand i get this error :
CreateDatabase Error :- 2147467259
Application: AbbrInHand
Reason Code: DBMS
Reason number: 2
what shall i do
thanks
Dear Kalim,
I am not sure if you had installed the AppForge Booster for Nokia Communicator 9210 series, if you dont have the booster installed, please get the booster from http://www.appforge.com and install the booster and try again.
If you still face the same problem, please contact us @ [email protected]
Hope this helps
Tilak
Hi all,
I take this oppurtunity to help Mr. Kalim to trace a new kind of error in Abbr In Hand .
The Abbr In Hand (for Nokia Communciator Series) will not work if the application is installed in D: or E: drive of Communicator. THE ABBR IN MOBILE HAS TO BE INSTALLED IN THE C: OF NOKIA COMMUNICATOR.
With regards
Tilak
For Shubha Soft
http://www.shubhasoft.com
