How to access calendar from PC
5 replies · 6,839 views · Started 17 March 2010
If PC Suite or Ovi is running and your phone is connected you can access everything in it, like contacts and calendar.
What about if I want to access events in my calendar from my PC without having the phone connected?
Is there a way to see calendar data stored i.e. in a backup of your phone?
This could be interesting if you'd loose your device and want to access the list of important meeting contained in the last backup..
Max
mrochester wrote:Why don't you sync your contacts and calendar entries to Outlook?
Can you? (how? I can't find anything in PC Suite settings)
And can you sync to other clients as Thunderbird.. etc?
Anyway it's so strange that no program which lets you access stored data (as a backup) exixts..
Massimo
Sync refers to contact while what I need is to access the events of my calendar.
Any idea?
I noted from calendar you can "export" a single event: isn't there a way to export all the events?
I don't think that there's no way to access my calendar in the case I loose my phone!..
