GPRS T-Mobile US Help!
9 replies · 3,450 views · Started 20 March 2003
I have a Nokia 3650 running 2.4 with T-mobile service in San Diego.
Can someone tell me step by step how to configure my GPRS Settings?
I have looked everywhere ie "howardforums", "allaboutsymbian" and here and cant find answers and t-mobile doesnt SEEM know anything.
Here are my current settings
->Connection settings
->Access Points
->"GPRS WAP"
Connection name
-GPRS WAP
Data bearer
-GPRS
Access point name
-wap.voicestream.com
Username
-none
prompt password
-no
password
-**** (default)
Authentication
-Normal
Gateway IP Address
-216.155.165.50
Homepage
-http://216.155.174.84/servlets/mms
Connection Security
Off
Session mode
-Permanent
->Advanced settings
Phone Ip Address
-Dynamic
Primary name server
-0.0.0.0
Second name server
-0.0.0.0
Server address
-none
Port number
-0
When i try to use the Doris Browser using the above connection it says:
"DNS lookup failed"
WHAT AM I DOING WRONG?
ANY HELP WOULD BE MORE THAN APPRECIATED!
Try duplicating those settings on another GPRS access point but this time have the gateway as 0.0.0.0 and connect with Doris on this setting.
Normally does the trick...
Best 😊
will
Or that you are trying to use GPRS WAP. And doris browser wont work with it.
You must set up a GPRS internet connection.
when I first setup GPRS on my Nokia 8390, I just called T-Mobile tech support on the phone, and they told me all of the settings. I have them written down at work, and don't have it configured on my 3650 yet, so don't have any more information.
But just give them a call - they were really helpful for me. The settings are the same for any GSM phone on T-Mobile, so they aren't hardware specific.
Todd
I've had much less luck with T-mobile with my 3650 -- they've been very unhelpful about giving me support. T-mobile Wireless Data Group and Nokia Tech Support bounced me back and forth half a dozen times. Anyway, the settings that both t-mobile and Nokia ended up gaving me, which don't seem to work at all, were:
Data bearer: GPRS
APN: Internet2.voicestream.com
Gateway: 216.155.165.50
Homepage: wap.myvoicestream.com
Server address: getmorespeed.voicestream.com
Server port: 8080
When I attemt to use this, I just get timeouts.
Does anyone know what might be wrong with those settings?
I shall try the settings that Grizam gave and see if they work any better, but I am a bit confused why they are so different.
--G
I have T-Zones on my 3650 here in Washington DC, and it works fine. Here are my settings as outlined by T-Mobile:
Data Bearer: GPRS
Access Point Name: wap.voicestream.com
User Name: None
Prompt password: No
Password: [Change nothing here]
Authentication: Normal
Gateway IP address: 216.155.165.50
Homepage: http://wap.myvoicestream.com (don't forget http://)
Connection Security: Off
Session mode: Permanent
And those settings work for me. Make sure you have T-Zones activated on your account, or none of this will do anything at all.
Todd
anyone here tried the phone on Cingular(US) GPRS. I can't get mine up and running.
Use this it's the easiest way
http://www.nokiausa.com/phones/3650/1,1162,settings:1,00.html
[quote="mclaughlinc"]Use this it's the easiest way
http://www.nokiausa.com/phones/3650/1,1162,settings:1,00.html[/quote]
damn, beat me to it
