Hi everyone! I need some help from willing E71 owners to test a widget I've made to see if it works on it. First, a little background.
I've produced a Weight Watchers Widget that calculates the points value of foods when the calories, saturated fat, and fibre values are provided. The widget was originally written for S60v5 devices like the 5800 and N97. Recently I was asked by an E71 owner for some help getting it to work on his phone, and I explained I'd made it for S60v5 and not S60v3. However, not one to disappoint, I quickly re-designed the widget so it was suitable for non-touchscreen S60 devices so he (and possibly others) could use it too.
I installed it on my N95 which, if I understand correctly, uses the same version of the SymbianOS as the E71 and, again if I understand correctly, if I switch the N95 to landscape mode the widget would show on the screen the same way it would on an E71. It ran perfectly fine (although I could do with lining up some of the form elements a little better) and would do the calculations as expected. Unfortunately, the E71 owner who contacted me about this is still experiencing difficulties installing it.
I'm currently waiting for my timeslot to come up on Nokia's Remote Device Access site so I can try it there, but since I don't own an E71, could someone here have a go at installing and using this widget to see if it works ok? It can be found on my website at: http://www.andrew-irvine.co.uk/php/php_blog/static.php?page=weightwatcherswidget
I know this sounds like a shameless plug but I assure you it's not 😊
Thanks in advance!!
