i cant get my phone off number mode!!!!
3 replies · 1,576 views · Started 20 March 2003
i cant get my phone off number mode!!! when i go to phone setting the following message comes up:
App.Closed gs CONE 14
help!!!!!!!!!!!!!
Don't fear. I found out that it is a bug in Wildskins 3 that does that. You tried installing wildskin 3 before this happened right? The solution is to get a copy of Wildskin 2 and install it. Activate it and you will get your characters back. After that uninstall the Wildskin 2. 😃
thanks cahpas, after reading earlier posts i found someone that had a similar problem. Yes i did install wildskin. I used a hard reset by keying *#7370# and that worked!
