:roll:
it there any way that i can install Real One [the same Real One that n3650 is using] because it is the only software that i need right now. when my bro [using 3650] sends me video i cant view it bec i dont have Real One, but i can send him video & he views it perfectly, only that it has very thick black boarder.
is it possible that i can install the same Real One in my 7650 so i can view videos? how? what site can i download?
thanks a lot!
p.s.
my hantro still shows 400++ KB, how can i compress it?
:roll:
Download the RealOne Player for 7650 at http://www.realnetworks.com/mobile/player/nokia60/index.html
Use SmartCompress from http://www.symbianware.com
Note: Seems that Application manager in Nokia is not accurate that is why it shows 400+ of Kb for hantro
Realone is BIG - download the nokia 7650 videoplayer for the nokia site - much smaller and now allows you to play the vids sent to your inbox.
Best 😊
Will
But it will not play MP4's only 3gp files
Bob
i did installed real one, but still cant view videos sent by 3650.
am i doing something wrong? it says "unable....objects...."
willbrady, can i really play videos in my inbox w/out the realone, how? bec when i tried it, this error comes out "multimedia unknown file format" does it have something to do w/ my service provider [i dont think so], or just how i use it... everybody! please tell me how.........
You need the NEW video software for the 7650 which is on the Nokia site, don't get confused with the 3650 one which was released a couple of days ago that also works on 7650 but does not allow playing from the inbox, the NEW one is for 7650 and allows playing from the inbox.
Here:
http://www.nokia.com/NokiaHome/0,5184,3930,00.html?applicationId=314&disclaimerAppID=1&disclaimerId=9&fileId=3731&parentId=2019&languageId=1
Bob is right this WILL NOT play mp4 but WILL play the 3gp files taken with a 3650.
And in this player it will be FULL screen and NOT with that black boarder that RealOne has 😉
Have fun - hope you get it all working.
Best 😊
Will
Thank you very much! It worked! GREAT!!!
i love this phone. i was thinking of selling my 7650 bec 3650 have the video function, but now it works w/ 7650!
my only concern is the memory... hehehe... bec i like to save a lot, anyway, ill just deal w/ it. besides, you cant always get the perfect one.
THANKS A LOT! YOU ALL ARE SO UP TO DATE!
[quote="SweetBaby"]Thank you very much! It worked! GREAT!!!
THANKS A LOT! YOU'RE SO UP TO DATE! [/quote]
[quote="SweetBaby"][quote="SweetBaby"]Thank you very much! It worked! GREAT!!!
THANKS A LOT! YOU'RE SO UP TO DATE! [/quote][/quote]
heard some rumour somewhere before on the net that nokia was considering coming up with a 7650i version or something similar. The difference is that the i version comes with an expandable memory slot i.e. mmc card or sd card. Not sure how true or accurate is the info.....
[quote="prozac"]
heard some rumour somewhere before on the net that nokia was considering coming up with a 7650i version or something similar. The difference is that the i version comes with an expandable memory slot i.e. mmc card or sd card. Not sure how true or accurate is the info.....[/quote]
oh no!!! here we go again...... :roll: 😃
yet another 7650i thread begins
you can all say "I was there !"
