hello
My "3/y" key not working at all ... initially was stuck on ..after a few presses trying to get it to release ...then doesn't work at all... i have replace keyboard flex but still not working, any ideas on what could the fault be?
Peter
hello
Peter
bump!
I'm having the same exact problem. I picked up my phone today to text someone and my 3/y key doesn't work, just out of the blue.
I didn't drop it, get it wet, update it or install anything new. If I keep tapping the 3/y key about a minute later it will start spitting it out. But even after that, if I try to press the 3/y key, nothing happens.
I tried turning it off and turning it back on - took the battery out - blew it out with compressed air....I don't know what else to try.
I searched on other forums but I can't find a resolution. Thanks in advance.
now all it does is repeat 3/y so when I have my phone in my pocket and I take it out theres a million 3s
