Can anyone help,
I have been trying to use skyfire to look at tv catchup sites, but every time I get a message from the site saying that I am not in the UK. I am based in the UK and using a uk ISP.
Any ideas?
Julian
Can anyone help,
Any ideas?
Julian
That isnt a skyfire problem... Happened to me then worked all of a sudden..
Also happend on www.seesaw.com
you will just have to keep trying...
If you're connecting through wireless rather than your data plan then it could be a proxy issue - you can check this site here to see what country your IP is showing it's from http://www.my-proxy.com/ip-to-country
If that's wrong then check your router settings.
If you haven't then try connecting through your 3G network rather than wireless and see if you still have the same problem.
