cant get latest Ovimaps for N97
3 replies · 5,252 views · Started 06 April 2010
Hi I took my phone to the local nokia care centre the other day to change the lens on the back due to the scratching cover issues.
When I got it back it had been re flashed and it had the old version of ovimaps on it, I tried to update to the latest version with the free satnav but according to the software update function on the phone it is up to date I cant seem to find any way of getting it back. I cant download from nokia it says every time to use the software update feature on the phone. Any ideas .
Try doing a hard reset and then, before doing anything else, check for the Maps update.
I'm guessing that after you got it back from repair that you did a restore on your phone and then tried to load Ovi Maps.
I ended up going to the nokia betalabs site and downloaded the latest version from there, will give it a go later but looks ok so far.
marzy wrote:Hi I took my phone to the local nokia care centre the other day to change the lens on the back due to the scratching cover issues.
If you are still looking for the latest (with free-nagivation) SIS file (non-beta), I think I have it at home - PM me.
