Problems with camera
9 replies · 2,457 views · Started 20 March 2003
Sometimes when I start the communicam I get the sony logo in the window where I usually se the picture, and the only way to correct this problem is to turn of the phone and start it up again. Sometimes the loga just showes for a very short while. Why? Do anyone had this problem?
You may be a bit shy of memory. Try running the file manager, going into task list and ending anything you aren't running. Don't worry about accidentally stopping anything - it's symbian so they all exit neatly or tell you if they can't be stopped. When you've cleared a bit of your memory (or try deleting things you've stored internally) the camera should work fine...
Rich.
Ive also experienced this.. Yesterday on the Golf course actually, it amde me miss some beautiful shots 😞 I had to quickly restart my phone and everything was ok.
Okay, thanks for the help. Glad I'm not the only one with this problem 😃
By the way, nice pic Muzikfreakah :angel:
Where do I find the task list in the file manager to end runnings I don�t need?
Ciao
Christian
Dummian I think this question is off topic but ill answer it anyway 😊 You have to use third party aps to be able to open task lists and end aps that are running. Aps like Hand Day, switcher or qfilemanager will all do the trick 😊
it would be great if P800 has a third party sw i.e SpaceDoubler or Stacker which were made for Series60's fone.
be patient ..... Psiloc already commit on SDOUBLER for P800 .. be patient mate, the thing will come .... 😃
Come to think of it, i don't think i have seen that SE logo on my communicam screen ever since i upgraded. It's probably just a bug & will be fixed with a firmware upgrade on your phone.
