Train the nokia shortcut bot
0 replies · 2,364 views · Started 14 April 2010
Surely I'm not the only one that downloaded the nokia bot just for the extra shortcut bar?
Having the shortcut bot 'learn' which apps to place there is a nice idea but I wish there was a manual override.
If your shortcut bot is displaying a shortcut that you don't want, add that shortcut to one of the original shortcut bars. Keep doing this until the shortcut bot has four shortcuts that you actually want on the homescreen then lock the shortcut learing process. Now you just have to fix the shortcuts on the standard shortcut widgets.
Is that a record for the most uses of the word 'shortcut' in a single post? Just in case it isn't...
shortcut shortcut shortcut shortcut shortcut shortcut shortcut
