Being such a helpful bunch, I wondered if any of you had come across this..
When using the internet connection, I want to bring up a terminal window when dialling, Should be easy there is an option for it under the "advanced settings" tab
However when you select YES to bring up a terminal window, when you dial, it doesn't bring up the terminal window - any suggestions ???
We Use SecureDial at the office ( with RSA tokens ) it requires a Terminal Window to login..
Is there a version of Excel for the communicator rather than the Excel Viewer ??
Regards
Terry
