Directory of Themes files in microSD.
2 replies · 6,652 views · Started 17 April 2010
Hi.
I just bought my brand new nokia 5233 cellphone and I am a newbie for this kind of cellphone.
Where in the directory of my microSD I put my themes files?
Themes are installed automatically , when clicked , in a folder which is invisible using the default filemanager .
The folder is Resource > Skins . The files have only coded names with letters and figures . The folder can be viewed by third party Filemanagers , like Y-Browser (found in OVI store) . The filemanager I use mostly is : X-Plore : http://www.lonelycatgames.com/?app=xplore .
The trial version is everlasting . Another one is :
-- Active File
http://alietan.com/
When you want to store a file , you can do that in any folder . You can make as many folders as you like with filemanager .
😊 Regards jApi NL
