Hi !
is it posible to backup only de conacts of my 7650?
and how cause Pc suite backup everything
thanks in advance 😊
Hi !
thanks in advance 😊
No its not possible (or it is but it is so complicated, you dont want to do it)
Just back up everything. It takes only 4MB...
Hmmm... If I'm understanding right... Isn't Outlook synchronization the answer... :-?
That is what I'm doing 😊
I sync only the contacts, calendars and notes (Task is device overwrites PC and copy entries of device to PCcoz my phone is more up-to-date than my PC)
If I will reformat and wish to get back the copy of my contacts, I will just change the task to Copy PC entries to device and PC overwrites the device :angel:
easier than ever 😃
In Outlook, it have Task and Note. In our phone, we have ToDo list and notes.
Question ask: How can these 2 data be sync with outlook? Anyone try b4?
Thanks for the reply's guy's 😃
