hello boys and girls,
I've got an N97 on Vodafone (UK) im wondering how i remove the following apps completely from the handset:-
JoikuSpot
Boingo
Qik
Vlingo
There doesnt seem to be an 'Uninstall' option anywhere that i can find :con?.
I have NSS so i can change the product code if required 😉.
Any help Appreciated 😊
Rich
They're part and parcel of the firmware I'm afraid.
Create a folder under 'Applications' called 'Unused', and put all the bundleware crap in there. That's the best you can do, unfortunately.
jamessmith01 wrote:Create a folder under 'Applications' called 'Unused', and put all the bundleware crap in there. That's the best you can do, unfortunately.
Exactly . It also a good place for apps , you wouldn't like to uninstall for possible future use or for the leasure times .
It's a big folder allready , soon I need a second one .
😊 Regards jApi NL
