hey guys!
i've just purchased nokia 3650 w/ t-mobile. i just downloaded pc suite and also bluetooth card. is it possible to transfer audio and video files to the phone from pc without subscribing to gsm service? please show me how if its all possible...thanx guys
download audio and video files w/ bluetooth using pc suite?
You need to pair the phone & the BT, PC Suite should detect the connection... once they are connected, you can start transferring your audio and video files from pc to your phone using a bluetooth.
hi...i tried that and i was able to transfer image files but not audio and video files. do i need to set up an inbox or something? thanx
When you first installed Nokia 3650 PC Suite, there is an option for us to check a dialogue box on whether to install the audio and video conversion. Did you install it? if yes, there shouldn't be a problem....
Open PC suite, browse for your audio or video files in your pc drive. Navigate thru MMC memory (below pane) for E:\Sounds\Digital. Transfer your audio files from pc to E:\Sounds\Digital. While PC Suite is transferring it, it will automatically convert the files to the format that will be recognize by the phone (e.g. mp3 > wav)
Videos should be transferred to E:\Videos
