Internet problem on X6
2 replies · 6,108 views · Started 22 April 2010
I have found with my new nokia x6 that when I connect to internet and perform a search on google or yahoo the results appear OK but if I try to click on the search results the page won't open. The connection manager says inactive connection?
If I switch off my phone and turn it back on it works again for a little time then starts to happen again.
Any Ideas.
There is a problem with sim card internet connection provider. You can get reset connection form your mobile internet connection provider the you can try to open any website in mobile phone.
keveenjones wrote:There is a problem with sim card internet connection provider. You can get reset connection form your mobile internet connection provider the you can try to open any website in mobile phone.
Is this all network providers? I can access internet just sometimes it seems to lock up and links won't open.
