how to get sound folder back
4 replies · 2,263 views · Started 21 March 2003
help please!
i accidentally deleted the sound file (both digital and simple) in realone player in the phone's main system. i wanted to transfer some mp3 songs from pc via pc suite into the fone, but i couldnt do it anymore. is there any way to retrieve the main sound file or folder so i can transfer files into it? please help...thank you
hi daniatt!
i just downloaded the file manager into the fone, but i dont know how to recreate the sound folder (digital and simple) back into the phone's system. would you be kind enough to give me a short tutorial...thank you very much
[quote="ditty"]i just downloaded the file manager into the fone, but i dont know how to recreate the sound folder (digital and simple) back into the phone's system. would you be kind enough to give me a short tutorial...thank you very much[/quote]
1. Open the filemanager app
2. go to c:/nokia/Sounds/
3. press select
3. choose file
3. choose Make Dir
4. type Digital
5. Ok
6. repeat with simple.
(that was assuming you use FExplorer)
Can you not just use the 'new folder' option in RealOne and put them back?
Saves getting filemanager - thou filemanager is good to have anyways 😊
Will 😊
