P800 + GPS
6 replies · 2,161 views · Started 21 March 2003
http://www.blueunplugged.com/
Should work with the citymap software I think...
[quote="Muppet"]http://www.blueunplugged.com/
Should work with the citymap software I think...[/quote]
AFAIK there's no support for this device in P800 as of yet, can you provide us with proof of the contrary?
I recall seeing a Memory Stick GPS module for the Clie. It would be cool if Sony would release a DUO version to work with the P800.
Apparently it works with the Tom-Tom maps software, and these are starting to appear for citys, so others should be available soon(ish). They've been done for Symbian before. As I understand it, the support doesn't need to be in the P800, it's up to the software running to do the communication via BT, so we're just waiting on suitable mapping programs.
Sure could use this for my GF - she can't find here way out of our drive... :-?
Are there any maps for the Philippines?
That would be cool if they did. I could make use of that from time to time.
