Issues with wifi and PEAP
1 replies · 7,391 views · Started 27 April 2010
on trying to connect to a wifi network with an E55 I have big issues.
Access point uses WPA2 authentication with PEAP (i.e. no shared key but authentication against a server) and MSchap.
I am carefully following instructions that the people who set up the network have prepared for nokia S60 phones. I have been confirmed that these instructions are correct and work fine.
However, on my E55 it is impossible to connect.
Every time I get an error:
"Unable to connect. WLAN network not found".
To me this is most likely a firmware bug.
I have updated to the latest firmware, btw.
Also I would tend to consider as a bug the very error message that is provided.
What does it mean "Wlan network not found" just after you said that you found that network and when every single laptop around can connect to it? This message is completely misleading, wrong and uninformative.
Since I am relatively new to Nokia S60 Edition 3 phones, I wonder if someone can provide me hints about this issue. BTW, is there any "official way" to provide formal bug reports to Nokia?
As I don't have a straightforward solution for your request I'll provide some links . I hope you will find the answer :
-- no gateway reply......in wifi connect (5800) -> Static ip adress
http://www.allaboutsymbian.com/forum//forum/thread/87069/
-- WPA2 does not work with E90
http://my-symbian.com/forum_mobile/viewtopic.php?t=40647&sid=c0537878e63f4d55d1d1c264d6de6814
-- W960i & WLAN (WPA/TKIP)
http://www.allaboutsymbian.com/forum//forum/thread/68249/
-- Nokia Support Discussions
http://discussions.europe.nokia.com/
-- Nokia Support Site
https://support.nokia.com/home
-- Nokia Europe - Product Support - Support
http://europe.nokia.com/support/product-support
Email : [email][email protected][/email]
😊 Regards jApi NL
