how to rename the fifa2003 file to .jar
4 replies · 3,006 views · Started 21 March 2003
You need to rename on your pc.
Open the fifa folder. Click on view>folder>view. Then uncheck the "hide extensions for known file types". Then just rename the fifa2003.zip to fifa2003.jar.
Also take note that this forum has a search function situated in top right of your screen. 😉
Ha Ha i find posts like this so amusin.
Whos the "STOOPID SPAG" now,
if you had bothered to read the previous posts you would have seen the question was
how do i rename the fifa2003 to a .jar file?
Obviously he is talikin about a zip file.
Man i get so infuriated with (most) guests posts :agrue: :evil: :2gunfire: :vamp: :angel:
