Nokia X6 debranding to v 20.0.5?
31 replies · 63,717 views · Started 01 May 2010
i got a nokia x6 16gb rm-559 all black from 3g uk today and would like to know if its possiable to debrand it, to remove all the network 3 crap and change it to original nokia software that includes normal, unbranded phone software.
current product code is: 0595750, current software version is: V 12.0.091
what product code do i use to upgrade firmware to 20.0.5?
Also, how would I go about unlocking the phone for use with other sims?
Any help would be appreciated 😊
I have already debranded, changed the product code via NSS and used software updater to update firmware.
You can find a complete list of product codes using Navifirm 0.1 however this is the one which I used
0589475: RM-559 CTR 16GB EURO1 DARK_BLACK UK
A warning about debranding from Three UK not sure if you have any of the additional apps like Skype and MSN but if you debrand to non 3 firmware you may potentially lose these and the benefits you get from them. Not sure if it applies to the X6 though it used to with the N95 when it wipes the entire phone. Thinking about it I do not appear to have lost any of the previously installed apps, just the rubbish T-Mobile branding.
For unlocking I am afraid I don't know.
I'm new to this forum. I've just bought a Nokia X6 but its locked to orange and I want to debrand it as I will be getting it unlocked soon and then using it on another network. Please can someone tell me exactly whats involved in debranding and how to do it as I dont have a clue. Thanks
You need NSS, NSU and a vanilla product code.
NSS is Nemisis Service Suite, an application that will let you change your product code. Be warned that changing your product code will invalidate your warranty and therefore you carry out this procedure entirely at your own risk. Its recommended to change the product code back when you are finished (your true prod code is under the battery)
NSU is Nokia Software Updater. This will connect you up to Nokia to pull down the latest firmware. Will be attached to your Ovi or PCSuite or can be downloaded separately.
Use the search on the forum, there are a few debranding stickies I think in the N95 section and all the info you need should be there.
Thanks mate. So with this product code, once I've changed the product code, this allows me to update the firmware from nokia to an unbranded firmware I'm guessing?? Once I've done this can I then change the product code back to the original and the phone will stay unbranded? Thanks
Yes once the phone has been updated you can change the product code to whatever you want and it won't change the firmware. One point to note though is that if you want future updates you will have to change the product code again, I just leave mine as is once I have updated that way I can always update the firmware whenever I want.
I found that when I debranded I had to use the PC software updater, I think the old T-Mobile firmware setup was blocking the FOTA. If you are in the UK with an X6 16Gb I would suggest you use this product code, it worked for me.
thanks for your help mate but please could you do a walkthru if possible of how to do the debranding as I'm still a bit confused. I understand the concepts of it but havent got a clue on what to do otherwise. I downloaded navifirm and had a look at that but found it quite confusing and also didnt understand the final column as there are multiple files. it would be a great help to do a walkthrough though. also, whats FOTA?
thanks
I changed the product code on my X6 in exactly the same way I did my old N95, there is a perfect guide here
http://www.allaboutsymbian.com/forum//forum/thread/67130/
Navifirm is a little confusing you don't need to worry about the last column just choose a suitable product code or use the one I used, which is a good EURO1 code.
FOTA is firmware over the air, it should allow you to upgrade your phone without have to connect it to a PC, I found however that the old T-Mobile firmware did not allow me to do this, so I just used Nokia software updater on my PC.
Finally remember to back up your user data, the X6 firmware shouldn't wipe it and it did not when I debranded mine but it is better to have it just in case
thanks for all your help mate. so when I change my product code and do the update i'm guessing that the phone/update program will automatically then find the latest firmware and download/install it or do I have to choose the firmware that i want installed? also, I installed the nokia ovi suite which is the current software updater/date suite but where abouts in it is the bit for updating the firmware? sorry for all the questions but I think the software isnt very clear. considering i'm an IT techie I shouldnt really be asking all these questions but when somethings new u gotta learn one way or another lol
When you have changed the prod code NSU will see that go, trot off to the server and match that code to latest fw. You dont need to pick anything. NSU should say to you when it looks, you have the latest firmware or there is a firmware update.
If you look under TOOLS you will have SOFTWARE UPDATE and it should tell you there that there is software available.
Navfirm list as of 19th May 2010:
0598909: Nokia X6 RM-559 3 AT AT Black Black Free Navi V2
0599488: Nokia X6 RM-559 3 SE SE Black black Free Navi V2
0595750: Nokia X6 RM-559 3 UK GB V2 Free Navi (Black Black)
0598785: Nokia X6 RM-559 Cosmote GR Black Black Free Navi V3
059B9W9: Nokia X6 RM-559 Cosmote GR Free Navi Black Red V3_COLOR
0595778: Nokia X6 RM-559 Country Variant China CN 16GB White/Yellow for Expo
0596651: Nokia X6 RM-559 Country Variant Croatia HR black black Free Navi v2
05999K2: Nokia X6 RM-559 Country Variant Czech Republic CZ 16 GB Black Free Navi V2
0597339: Nokia X6 RM-559 Country Variant Denmark DK Black Black Free Navi V2
0599024: Nokia X6 RM-559 Country Variant Finland FI BLACK_BLACK_Free_Navi_V2
0593613: Nokia X6 RM-559 Country Variant Finland FI CWM_DARK_RED_FREE_Navi_V2_COLOR
0593296: Nokia X6 RM-559 Country Variant Finland FI CWM_LIGHT_BLUE_Free_Navi_V2
0598165: Nokia X6 RM-559 Country Variant Hungary HU BLACK Free Navi V2 (MOS)
0597357: Nokia X6 RM-559 Country Variant Indonesia ID Nokia X6-16GB BlackBlack
0597496: Nokia X6 RM-559 Country Variant Indonesia ID Nokia X6-16GB White Pink
0593349: Nokia X6 RM-559 Country Variant Italy IT Free Navi Blue CWM V2_COLOR
0593354: Nokia X6 RM-559 Country Variant Italy IT Free Navi Red CWM V2
0598157: Nokia X6 RM-559 Country Variant Malaysia MY CWM Black Black
0593037: Nokia X6 RM-559 Country Variant Malaysia MY Dark Red Free Navi
0595692: Nokia X6 RM-559 Country Variant Netherlands NL CV CWM v2 Black/red Free Navi_CO
0593350: Nokia X6 RM-559 Country Variant Netherlands NL CV CWM v2 Light Blue Free Navi
0599290: Nokia X6 RM-559 Country Variant Nigeria NG 16GB Black Rihanna
0597342: Nokia X6 RM-559 Country Variant Norway NO Black Black Free Navi V2
0597471: Nokia X6 RM-559 Country Variant Romania RO BLACK Free Navi V2 MOS+50trcks
0592967: Nokia X6 RM-559 Country Variant Russia RU Free Navi black-red CWM V2
0592889: Nokia X6 RM-559 Country Variant Russia RU Free Navi white-blue CWM V2
0597341: Nokia X6 RM-559 Country Variant Sweden SE Black Black Free Navi V2
0593425: Nokia X6 RM-559 Country Variant Sweden SE DARK RED Free Navi V2
0593424: Nokia X6 RM-559 Country Variant Sweden SE LIGHT BLUE Free Navi V2_COLOR
0596142: Nokia X6 RM-559 Country Variant Switzerland CH Black Free Navi V2
0598552: Nokia X6 RM-559 Country Variant Switzerland CH White-Pink Free Navi V2_COLOR
05999Z5: Nokia X6 RM-559 Country Variant Switzerland CH White-white Free Navi V2_COLOR
0597775: Nokia X6 RM-559 Country Variant Taiwan TW White_Pink-FreeNavi V2_COLOR
0597749: Nokia X6 RM-559 Country Variant Taiwan TW Black_Black-FreeNavi V2
0598012: Nokia X6 RM-559 Country Variant Thailand
0598064: Nokia X6 RM-559 Country Variant Thailand TH LIGHT-PINK
0599985: Nokia X6 RM-559 Country Variant Ukraine UA X6 16GB Black V2 Free Navi
05999L6: Nokia X6 RM-559 Country Variant Ukraine UA X6 16GB White pink V2 Free Nav_COLOR
05999R7: Nokia X6 RM-559 Country Variant Ukraine UA X6 16GB White V2 Free Navi_COLOR
0595979: Nokia X6 RM-559 Country Variant United Kingdom GB Free Navi CU White/Pink V2_CO
0595749: Nokia X6 RM-559 Country Variant United Kingdom GB V3 Free Navi Black
0598558: Nokia X6 RM-559 Fastweb SpA IT Free Navi blackblack unloc V2
0599262: Nokia X6 RM-559 GLOBUL (Cosmo Bulgaria Mobile EAD) BG Black Free Navi V2
0593896: Nokia X6 RM-559 KPN NL CWM v2 Dark Red Free Navi
0599025: Nokia X6 RM-559 MTEL (MobilTel EAD) BG Black Black Free Navi V2
0595142: Nokia X6 RM-559 o2 Germany DE Black Free Navi Postpaid V2
0596498: Nokia X6 RM-559 O2 UK GB v2 Free Navi Blac\Blac Postpay
059B423: Nokia X6 RM-559 Pannon Hungary HU Free Navi BLACK BLACK 16 GB V2
0599201: Nokia X6 RM-559 Phones 4 U GB V2 Phones 4 U Free Navi B/B
0599257: Nokia X6 RM-559 Phones 4 U GB V2 Phones 4 U Free Navi Wh/Bl_COLOR
0599386: Nokia X6 RM-559 Proximus BE v2 black Free Navi_COLOR
0596955: Nokia X6 RM-559 Proximus BE v2 White Free Navi
05999Z6: Nokia X6 RM-559 Si.mobil d.d. SI black red Free Navi v2_COLOR
0597072: Nokia X6 RM-559 Si.mobil d.d. SI white white Free Navi v2
059B319: Nokia X6 RM-559 Smart Communications - Philippines PH 16GB Black SL Free Navi
0598569: Nokia X6 RM-559 T-Mobile Hungary HU BLACK V1 GV
0598562: Nokia X6 RM-559 T-Mobile SK SK BLACK-RED Free Navi V2 GV
059B2C2: Nokia X6 RM-559 Telenor Serbia RS Black Free Navi V2
0599781: Nokia X6 RM-559 TeliaSonera SE SE 16 GB Black Black Free Navi v2
059B8P0: Nokia X6 RM-559 Turkcell TR 16GB CWM V1 BLACK RED_COLOR
0598046: Nokia X6 RM-559 Virgin UK GB Free Navi Black Black v2
0598974: Nokia X6 RM-559 Vodafone Hungary HU Free Navi Black Red V2
0595513: Nokia X6 RM-559 Vodafone IT IT Free Navi White V2
0598173: Nokia X6 RM-559 Vodafone NL NL v2 White white Free Navi
0599492: Nokia X6 RM-559 Vodafone Romania RO Black Red Free Navi V2
05999T0: Nokia X6 RM-559 Vodafone Spain ES Black_Free Navi_V2_GV_COLOR
0595508: Nokia X6 RM-559 Vodafone Spain ES White_Free Navi_V2_GV
059B8W2: Nokia X6 RM-559 Yoigo ES ES Black Black 16GB
0578284: RM-559 APAC1 BLACK-RED CAMBODIA
0578301: RM-559 APAC1 BLACK-RED INDONESIA
0578281: RM-559 APAC1 BLACK-RED MALAYSIA
0578276: RM-559 APAC1 BLACK-RED SINGAPORE
0578408: RM-559 APAC1 LIGHT-BLUE CAMBODIA
0578409: RM-559 APAC1 LIGHT-BLUE INDONESIA
0578407: RM-559 APAC1 LIGHT-BLUE MALAYSIA
0578932: RM-559 APAC1 LIGHT-BLUE SINGAPORE
0578304: RM-559 APAC2 BLACK-RED AUSTRALIA
0578302: RM-559 APAC2 BLACK-RED BANGLADESH
0578305: RM-559 APAC2 BLACK-RED NZ
0578307: RM-559 APAC2 BLACK-RED PHILIPPINES
0578303: RM-559 APAC2 BLACK-RED SL NEPAL
0578440: RM-559 APAC2 LIGHT-BLUE AUSTRALIA
0578432: RM-559 APAC2 LIGHT-BLUE BANGLADESH
0578443: RM-559 APAC2 LIGHT-BLUE NZ
0578444: RM-559 APAC2 LIGHT-BLUE PHILIPPINES
0578433: RM-559 APAC2 LIGHT_BLUE SL NEPAL
0578264: RM-559 BALKANS BLACK-RED
0578380: RM-559 BALKANS LIGHT-BLUE
0578257: RM-559 BALTIAN BLACK-RED
0578372: RM-559 BALTIAN LIGHT-BLUE
0578308: RM-559 BLACK-RED INDIA
0598934: RM-559 Country Variant India IN X 6 16 GB Black v1
0593039: RM-559 Country Variant SG White Blue Free Navi v2.0
0598705: RM-559 CTR 16BG MEA-I L_WHITE SA
0589419: RM-559 CTR 16GB APAC1 D_BLACK CAMBODIA
0589420: RM-559 CTR 16GB APAC1 D_BLACK INDONESIA
0589418: RM-559 CTR 16GB APAC1 D_BLACK MALAYSIA
0589417: RM-559 CTR 16GB APAC1 D_BLACK SINGAPORE
0580293: RM-559 CTR 16GB APAC1 L_PINK CAMBODIA
0580294: RM-559 CTR 16GB APAC1 L_PINK INDONESIA
0580292: RM-559 CTR 16GB APAC1 L_PINK MALAYSIA
0580291: RM-559 CTR 16GB APAC1 L_PINK SINGAPORE
0580467: RM-559 CTR 16GB APAC1 L_YELLOW INDONESIA
0580445: RM-559 CTR 16GB APAC1 L_YELLOW MALAYSIA
0580443: RM-559 CTR 16GB APAC1 L_YELLOW SINGAPORE
0580466: RM-559 CTR 16GB APAC1 LIGHT_YELLOW CAMBODIA
0589424: Rm-559 ctr 16gb apac2 d_black australia
0589421: Rm-559 ctr 16gb apac2 d_black bangladesh
0589426: Rm-559 ctr 16gb apac2 d_black philippin
0589423: Rm-559 ctr 16gb apac2 d_black sl nepal
0589425: Rm-559 ctr 16gb apac2 dark_black nz
0580295: Rm-559 ctr 16gb apac2 l_pink bangladesh
0580299: Rm-559 ctr 16gb apac2 l_pink new zealand
0580297: Rm-559 ctr 16gb apac2 l_pink sl/nepal
0580468: Rm-559 ctr 16gb apac2 l_yello bangladesh
0580471: Rm-559 ctr 16gb apac2 l_yellow australia
0580470: Rm-559 ctr 16gb apac2 l_yellow sl/nepal
0580472: Rm-559 ctr 16gb apac2 light_yellow nz
0580473: Rm-559 ctr 16gb apac2 light_yellow philippines
0580306: Rm-559 ctr 16gb apac2 w_pink philippines
0580298: Rm-559 ctr 16gb apac2 white_pink australia
0595388: Rm-559 ctr 16gb balkans black_red
0589489: Rm-559 ctr 16gb balkans dark_black
0580288: Rm-559 ctr 16gb balkans light_pink
0580438: Rm-559 ctr 16gb balkans light_yellow
0595410: Rm-559 ctr 16gb balkans white_blue
0595381: Rm-559 ctr 16gb baltian black_red
0589480: Rm-559 ctr 16gb baltian dark_black
0580281: Rm-559 ctr 16gb baltian light_pink
0580428: Rm-559 ctr 16gb baltian light_yellow
0595403: Rm-559 ctr 16gb baltian white_blue
0589411: Rm-559 ctr 16gb china wapi d_black
0592038: Rm-559 ctr 16gb china wapi light_pink
0592040: Rm-559 ctr 16gb china wapi light_yellow
0595371: Rm-559 ctr 16gb euro1 black_red alps
0595369: Rm-559 ctr 16gb euro1 black_red france
0595372: Rm-559 ctr 16gb euro1 black_red italy
0595374: Rm-559 ctr 16gb euro1 black_red portugal
0595180: Rm-559 ctr 16gb euro1 black_red uk
0589474: Rm-559 ctr 16gb euro1 d_black portugal
0589470: Rm-559 ctr 16gb euro1 dark_black alps
0589468: Rm-559 ctr 16gb euro1 dark_black france
0589472: Rm-559 ctr 16gb euro1 dark_black italy
0589473: Rm-559 ctr 16gb euro1 dark_black malta
0589475: Rm-559 ctr 16gb euro1 dark_black uk
0582367: Rm-559 ctr 16gb euro1 l_pink portugal
0582373: Rm-559 ctr 16gb euro1 l_pink uk ireland
0582376: Rm-559 ctr 16gb euro1 l_yello uk ireland
0580412: Rm-559 ctr 16gb euro1 l_yellow alps
0580410: Rm-559 ctr 16gb euro1 l_yellow france
0580414: Rm-559 ctr 16gb euro1 l_yellow italy
0582365: Rm-559 ctr 16gb euro1 l_yellow malta
0582371: Rm-559 ctr 16gb euro1 l_yellow portugal
0580274: Rm-559 ctr 16gb euro1 light_pink alps
0580273: Rm-559 ctr 16gb euro1 light_pink france
0580275: Rm-559 ctr 16gb euro1 light_pink italy
0582362: Rm-559 ctr 16gb euro1 light_pink malta
0595397: Rm-559 ctr 16gb euro1 w_blue portugal
0595394: Rm-559 ctr 16gb euro1 white_blue alps
0595393: Rm-559 ctr 16gb euro1 white_blue france
0595395: Rm-559 ctr 16gb euro1 white_blue italy
0595398: Rm-559 ctr 16gb euro1 white_blue uk
0595437: Rm-559 ctr 16gb euro1 white_white italy
0595682: Rm-559 ctr 16gb euro1 white_white uk
0595377: Rm-559 ctr 16gb euro2 black_red benelux
0595378: Rm-559 ctr 16gb euro2 black_red germany
0595376: Rm-559 ctr 16gb euro2 black_red turkey
0589478: Rm-559 ctr 16gb euro2 d_black germany
0589477: Rm-559 ctr 16gb euro2 dark_black
0589476: Rm-559 ctr 16gb euro2 dark_black turkey
0582392: Rm-559 ctr 16gb euro2 l_yellow germany
0580416: Rm-559 ctr 16gb euro2 l_yellow turkey
0580278: Rm-559 ctr 16gb euro2 light_pink
0582389: Rm-559 ctr 16gb euro2 light_pink germany
0580419: Rm-559 ctr 16gb euro2 light_yellow
0595435: Rm-559 ctr 16gb euro2 w_white germany
0595400: Rm-559 ctr 16gb euro2 white_blue benelux
0595401: Rm-559 ctr 16gb euro2 white_blue germany
0595399: Rm-559 ctr 16gb euro2 white_blue turkey
0580277: Rm-559 ctr 16gb euro2 white_pink turkey
0595387: Rm-559 ctr 16gb euro3 black_red
0589488: Rm-559 ctr 16gb euro3 dark_black
0580436: Rm-559 ctr 16gb euro3 l_yellow
0580286: Rm-559 ctr 16gb euro3 light_pink
0595409: Rm-559 ctr 16gb euro3 white_blue
0595391: RM-559 CTR 16GB HEBREW BLACK_RED
0589490: RM-559 CTR 16GB HEBREW D_BLACK ISRAEL
0580439: RM-559 CTR 16GB HEBREW L_YELLOW ISRAEL
0580289: RM-559 CTR 16GB HEBREW LIGHT_PINK ISRAEL
0595411: RM-559 CTR 16GB HEBREW WHITE_BLUE
0595392: RM-559 CTR 16GB HISPANIA BLACK_RED
0589491: RM-559 CTR 16GB HISPANIA DARK_BLACK
0580290: RM-559 CTR 16GB HISPANIA LIGHT_PINK
0580441: RM-559 CTR 16GB HISPANIA LIGHT_YELLOW
0595412: RM-559 CTR 16GB HISPANIA WHITE_BLUE
0595436: RM-559 CTR 16GB HISPANIA WHITE_WHITE
0589412: RM-559 CTR 16GB HONG KONG DARK_BLACK
0592047: RM-559 CTR 16GB HONG KONG LIGHT_PINK
0592048: RM-559 CTR 16GB HONG KONG LIGHT_YELLOW
0589428: RM-559 CTR 16GB INDIA DARK_BLACK
0580307: RM-559 CTR 16GB INDIA LIGHT_PINK
0580474: RM-559 CTR 16GB INDIA LIGHT_YELLOW
0589442: RM-559 CTR 16GB MEA-A D_BL ARABIC EU NAV
0589437: RM-559 CTR 16GB MEA-A D_BLACK ARABIC EU
0589439: RM-559 CTR 16GB MEA-A D_BLACK ARABIC KSA
0589443: RM-559 CTR 16GB MEA-A D_BLACK ARABIC UK
0589444: RM-559 CTR 16GB MEA-A D_BLACK NORTH AFRICA
0589446: RM-559 CTR 16GB MEA-A D_BLACK PAN-MEA
0589464: RM-559 CTR 16GB MEA-A D_BLACK SUDAN
0589461: RM-559 CTR 16GB MEA-A DARK_BLACK SYRIA
0582254: RM-559 CTR 16GB MEA-A L_Y ARABIC EU NAVI
0582258: RM-559 CTR 16GB MEA-A L_Y NORTH AFRICA
0582250: RM-559 CTR 16GB MEA-A L_YELLOW ARABIC EU
0582256: RM-559 CTR 16GB MEA-A L_YELLOW ARABIC UK
0582252: RM-559 CTR 16GB MEA-A L_YELLOW KSA
0582265: RM-559 CTR 16GB MEA-A L_YELLOW PAN MEA
0582263: RM-559 CTR 16GB MEA-A L_YELLOW SUDAN
0587160: RM-559 CTR 16GB MEA-A L_YELLOW SYRIA
0587159: RM-559 CTR 16GB MEA-A LIGHT_PINK SYRIA
0581527: RM-559 CTR 16GB MEA-A W_PINK ARABIC EU NAVI
0581535: RM-559 CTR 16GB MEA-A W_PINK NORTH AFRICA
0581510: RM-559 CTR 16GB MEA-A WHITE_PINK ARABIC EU
0581531: RM-559 CTR 16GB MEA-A WHITE_PINK ARABIC UK
0581511: RM-559 CTR 16GB MEA-A WHITE_PINK KSA
0581556: RM-559 CTR 16GB MEA-A WHITE_PINK PAN MEA
0581541: RM-559 CTR 16GB MEA-A WHITE_PINK SUDAN
0589447: RM-559 CTR 16GB MEA-C D_BLACK PAKISTAN
0589448: RM-559 CTR 16GB MEA-C DARK_BLACK IRAN
0589452: RM-559 CTR 16GB MEA-C DARK_BLACK UAE
0582260: RM-559 CTR 16GB MEA-C L_YELLOW IRAN
0582259: RM-559 CTR 16GB MEA-C L_YELLOW PAKISTAN
0582261: RM-559 CTR 16GB MEA-C L_YELLOW UAE
0581537: RM-559 CTR 16GB MEA-C WHITE_PINK IRAN
0581536: RM-559 CTR 16GB MEA-C WHITE_PINK PAKISTAN
0581539: RM-559 CTR 16GB MEA-C WHITE_PINK UAE
0589460: RM-559 CTR 16GB MEA-I D_BLACK NIGERIA
0589454: RM-559 CTR 16GB MEA-I D_BLACK SOUTH AFRICA
0589455: RM-559 CTR 16GB MEA-I D_BLC SOUTHERN AFRICA
0589457: RM-559 CTR 16GB MEA-I DARK_BLACK SSA
0582267: RM-559 CTR 16GB MEA-I L_YEL SOUTH AFRICA
0582275: RM-559 CTR 16GB MEA-I L_YELLOW NIGERIA
0582273: RM-559 CTR 16GB MEA-I L_YELLOW SOUTHERN AFRICA
0582277: RM-559 CTR 16GB MEA-I LIGHT_YELLOW SSA
0581545: RM-559 CTR 16GB MEA-I W_PINK SOUTHERN AFRICA
0581546: RM-559 CTR 16GB MEA-I W_PINK SSA
0581547: RM-559 CTR 16GB MEA-I WHITE_PINK NIGERIA
0581544: RM-559 CTR 16GB MEA-I WHITE_PINK SOUTH AFRICA
0589483: RM-559 CTR 16GB RUSSIA and BELARUS D_BLACK
0580434: RM-559 CTR 16GB RUSSIA and BELARUS L_YELLOW
0580284: RM-559 CTR 16GB RUSSIA and BELARUS W_PINK
0595384: RM-559 CTR 16GB RUSSIA/BELARUS BLACK_RED
0595406: RM-559 CTR 16GB RUSSIA/BELARUS W_BLUE
0595386: RM-559 CTR 16GB RUSSIAN B_RED HUNGARY
0595382: RM-559 CTR 16GB RUSSIAN B_RED MOLDOVA
0595383: RM-559 CTR 16GB RUSSIAN B_RED UKRAINE
0595385: RM-559 CTR 16GB RUSSIAN BLACK_RED CIS
0589487: RM-559 CTR 16GB RUSSIAN D_BLACK HUNGARY
0589481: RM-559 CTR 16GB RUSSIAN D_BLACK MOLDOVA
0589486: RM-559 CTR 16GB RUSSIAN DARK_BLACK CIS
0589482: RM-559 CTR 16GB RUSSIAN DARK_BLACK UKRAINE
0582383: RM-559 CTR 16GB RUSSIAN L_PINK HUNGARY
0580283: RM-559 CTR 16GB RUSSIAN L_PINK UKRAINE
0580435: RM-559 CTR 16GB RUSSIAN L_YELLOW CIS
0582385: RM-559 CTR 16GB RUSSIAN L_YELLOW HUNGARY
0580432: RM-559 CTR 16GB RUSSIAN L_YELLOW MOLDOVA
0580433: RM-559 CTR 16GB RUSSIAN L_YELLOW UKRAINE
0580285: RM-559 CTR 16GB RUSSIAN LIGHT_PINK CIS
0595408: RM-559 CTR 16GB RUSSIAN W_BLUE HUNGARY
0595404: RM-559 CTR 16GB RUSSIAN W_BLUE MOLDOVA
0595405: RM-559 CTR 16GB RUSSIAN W_BLUE UKRAINE
0580282: RM-559 CTR 16GB RUSSIAN W_PINK MOLDOVA
0595407: RM-559 CTR 16GB RUSSIAN WHITE_BLUE CIS
0595380: RM-559 CTR 16GB SCANDINAVIA BLACK_RED
0589479: RM-559 CTR 16GB SCANDINAVIA DARK_BLACK
0580421: RM-559 CTR 16GB SCANDINAVIA L_YELLOW
0580280: RM-559 CTR 16GB SCANDINAVIA LIGHT_PINK
0595402: RM-559 CTR 16GB SCANDINAVIA WHITE_BLUE
0589415: RM-559 CTR 16GB TAIWAN DARK_BLACK
0592050: RM-559 CTR 16GB TAIWAN LIGHT_PINK
0592051: RM-559 CTR 16GB TAIWAN LIGHT_YELLOW
0589430: RM-559 CTR 16GB THAI DARK_BLACK
0580309: RM-559 CTR 16GB THAI LIGHT_PINK
0580476: RM-559 CTR 16GB THAI LIGHT_YELLOW
0589429: RM-559 CTR 16GB VIETNAM DARK_BLACK
0580308: RM-559 CTR 16GB VIETNAM LIGHT_PINK
0580475: RM-559 CTR 16GB VIETNAM LIGHT_YELLOW
0586916: RM-559 CTR CHINA WAPI DARK_RED
0586917: RM-559 CTR CHINA WAPI LIGHT_BLUE
0578249: RM-559 CTR EURO1 BLACK-RED FRANCE
0578366: RM-559 CTR EURO1 LIGHT_BLUE FRANCE
0584983: RM-559 CTR NORTH AMERICA LIGHT_BLUE
0593034: RM-559 CV Malaysia MY White Blue - MR
0593044: RM-559 CV Singapore SG Dark Red - MR
0578251: RM-559 EURO1 BLACK-RED ALPS
0576719: RM-559 EURO1 BLACK-RED ITALY
0582361: RM-559 EURO1 BLACK-RED MALTA
0582366: RM-559 EURO1 BLACK-RED PORTUGAL
0582372: RM-559 EURO1 BLACK-RED UK IRELAND
0578367: RM-559 EURO1 LIGHT-BLUE ALPS
0576717: RM-559 EURO1 LIGHT-BLUE ITALY
0582364: RM-559 EURO1 LIGHT-BLUE MALTA
0582370: RM-559 EURO1 LIGHT-BLUE PORTUGAL
0582375: RM-559 EURO1 LIGHT-BLUE UK IRELAND
0578255: RM-559 EURO2 BLACK-RED
0582387: RM-559 EURO2 BLACK-RED GERMANY
0578252: RM-559 EURO2 BLACK-RED TURKEY
0578369: RM-559 EURO2 LIGHT-BLUE
0582388: RM-559 EURO2 LIGHT-BLUE GERMANY
0578368: RM-559 EURO2 LIGHT-BLUE TURKEY
0578262: RM-559 EURO3 BLACK-RED
0578378: RM-559 EURO3 LIGHT-BLUE
hi mate,
thanks again for all your help. I have tried changing the product code and used: 0595398, 0589475, and 0595180 but had no success with these codes as the phone wouldnt find any firmware updates once the code was changed so I've just changed my code back again. Is it ok to try the euro2 codes? whats the difference in these type of codes? also, do I have to use the code that corresponds with my phone ie, colour (black/red)?
I've now tried multiple codes but had no luck in updating the firmware and therefore debranding the phone. I'm not sure why it aint working but both over the air and using ovi suite there's no updates being picked up. whats going on?
Hmm, strange...
I'll check now see whats on...
You don't HAVE to have the one that matches your phone colour no... its just that you may have colour matching themes and the likes attached to it. (AFAIK)
Do you have a 32GB or 16GB??
few more that werent on list
0578265: RM-559 HEBREW BLACK-RED ISRAEL
0578381: RM-559 HEBREW LIGHT-BLUE ISRAEL
0578266: RM-559 HISPANIA BLACK-RED
0578382: RM-559 HISPANIA LIGHT-BLUE
0578311: RM-559 HONG KONG DARK-RED
0578451: RM-559 HONG KONG LIGHT-BLUE
0578446: RM-559 LIGHT-BLUE INDIA
0581425: RM-559 MEA-A BLACK-RED ARABIC EU
0581427: RM-559 MEA-A BLACK-RED ARABIC EU NAVI
0581426: RM-559 MEA-A BLACK-RED ARABIC KSA
0581428: RM-559 MEA-A BLACK-RED ARABIC UK
0581430: RM-559 MEA-A BLACK-RED NORTH AFRICA
0581558: RM-559 MEA-A BLACK-RED Pan-MEA
0581484: RM-559 MEA-A BLACK-RED SUDAN
0587158: RM-559 MEA-A BLACK-RED SYRIA
0581619: RM-559 MEA-A LIGHT-BLUE ARABIC EU
0581628: RM-559 MEA-A LIGHT-BLUE ARABIC EU NAVI
0581626: RM-559 MEA-A LIGHT-BLUE ARABIC KSA
0581629: RM-559 MEA-A LIGHT-BLUE ARABIC UK
0581630: RM-559 MEA-A LIGHT-BLUE NORTH AFRICA
0581640: RM-559 MEA-A LIGHT-BLUE Pan-MEA
0581636: RM-559 MEA-A LIGHT-BLUE SUDAN
0587162: RM-559 MEA-A LIGHT_BLUE SYRIA
0581456: RM-559 MEA-C BLACK-RED IRAN
0581431: RM-559 MEA-C BLACK-RED PAKISTAN
0581457: RM-559 MEA-C BLACK-RED UAE
0581632: RM-559 MEA-C LIGHT-BLUE IRAN
0581631: RM-559 MEA-C LIGHT-BLUE PAKISTAN
0581634: RM-559 MEA-C LIGHT-BLUE UAE
0581467: RM-559 MEA-I BLACK-RED Nigeria
0581464: RM-559 MEA-I BLACK-RED SOUTH AFRICA
0581465: RM-559 MEA-I BLACK-RED Southern Africa
0581466: RM-559 MEA-I BLACK-RED SSA
0582230: RM-559 MEA-I LIGHT-BLUE Nigeria
0581641: RM-559 MEA-I LIGHT-BLUE SOUTH AFRICA
0581642: RM-559 MEA-I LIGHT-BLUE Southern Africa
0582233: RM-559 MEA-I LIGHT-BLUE SSA
0578260: RM-559 RUSSIA and BELARUS BLACK-RED
0578376: RM-559 RUSSIA and BELARUS LIGHT-BLUE
0578261: RM-559 RUSSIAN BLACK-RED CIS
0582381: RM-559 RUSSIAN BLACK-RED HUNGARY
0578258: RM-559 RUSSIAN BLACK-RED MOLDOVA
0578259: RM-559 RUSSIAN BLACK-RED UKRAINE
0578377: RM-559 RUSSIAN LIGHT-BLUE CIS
0582382: RM-559 RUSSIAN LIGHT-BLUE HUNGARY
0578374: RM-559 RUSSIAN LIGHT-BLUE MOLDOVA
0578375: RM-559 RUSSIAN LIGHT-BLUE UKRAINE
0578256: RM-559 SCANDINAVIA BLACK-RED
0578370: RM-559 SCANDINAVIA LIGHT-BLUE
0578312: RM-559 TAIWAN DARK-RED
0578452: RM-559 TAIWAN LIGHT-BLUE
0578310: RM-559 THAI BLACK-RED
0578449: RM-559 THAI LIGHT-BLUE
0578309: RM-559 VIETNAM BLACK-RED
0578448: RM-559 VIETNAM LIGHT-BLUE
0599957: RM-559_SingTel_SG _White Pink_V2_COLOR
reganlives wrote:its a 16GB mate.
Ahhh ok... Im on 32GB, anyway... hit me up on MSN
FYI tho... 0582375: RM-559 EURO1 LIGHT-BLUE UK IRELAND showing v20.
Good news is that there is UDP on the X6 😉
whats your msn addy mate so I can discuss this further with you? I'm going to try that code out now so hope it works. also, you say UDP is on the XP, as in the IP protocol?
I'm doing an over the air update at the moment as nothing came up using the ovi software. Tried doing *#0000# then update but nothing came up but now loads has come up under the normal update bit within applications. Does it tell you when its doing the firmware update or will it prompt you as it took a while to search for updates?
When you enter *#0000# what firmware version does it say you are on?
If the previous product codes did not work with NSU then it sounds like you are already on the latest firmware, as you are on a branded firmware this may be a slightly newer/updated version, so NSU might be right in saying there is nothing to update to.
Hi folks Just regisitered as I wanted to forward the pinout for the X6-00 if you wanted to unlock it yourself using JAF. there's no specially made cable for it yet that i've found so far but it can be unlocked using the universal kit and cable 9 with a JAF box or similar. did this myself with my own X6-00 and it worked a treat so thought i'd put it here. not sure about debranding the phone but by the sounds of it if you want to keep some of the worthwhile features you're better to leave things as is. hope this pin out helps those of you who want to unlock an x6
Attachments: 01012009014.jpg
As far as i can recall you can pick one up from ebay for around �30 to �40 and a unversal kit for the jaf box for around �20. considering that the price both together are around �50 or so its definatly worth the money and is fairly easy to use for unlocking depending on the phone model you want to unlock
Hi people.
I am trying to debrand my X6 on Orange. I have read and changed my product code using NSS. I then use NSU to search for the updated software but just get the message that my software is up to date. Is there any workaround for this?. Any help greatly appreciated.😊
I would suggest a different product code. Keep trying till you find one that works.
yeah, I think UKJeeper has added to your post but have a try with another code, and also make sure that you are actually writing that code to the handset.
