Micro-SD card used in E52 can not be used elsewhere
2 replies · 9,305 views · Started 02 May 2010
Hello,
I would like some help. I have used a 4 gig Micro sd sdhc card in my E52 and it works without problems. I am have been trying to use this memory card in a camera and in my card reader on my laptop without success. When a place the card in my card reader it does allocated as a removable disk on my computer. Other sdhc cards works in the card reader. The micro sd card can not be read in my camera either. If I connect the E52 by USB cable the memory card shows up as a removable disk on my computer. I�ve tried formatting the card when placed in E52, connected to my computer by USB-cable and the format completes without problems. But still the card can not be read anywhere else but in the phone. I have also tried formatting the card in the phone.
What can be wrong? There is no password on the memory card from what I can see.
Any solution to this is much appreciated.
Raveot2 wrote:Hello,
There is a well-known issue with Nokia phones, which may or may not explain your problem. If you set up a message to lock your phone by SMS and you have not previously defined a password for your memory card, the message you choose will also be used as a password for your memory card, WITHOUT you being alerted to this fact. If at some point you want to use your card in another device, you can't unless you remember the password.
Although the idea of password protecting the memory card is good, it should NEVER be done without the user's say so and should certainly not use some form of random passwords, as is currently the case.
I' m not saying this is the case in your case, but it is certainly a possibility...
