Hello. How to change the frequency (length) of vibration (SMS, call)? I looking for a way (aplication, patch, etc.) to change the speed of vibration.
How to change the frequency of vibration?
As far as I know , only an On / Off in the Profile Settings ...
😊 Regards jApi NL
Just saw on Getjar an App called Vibrator , 37 different positions or so . It's a paid for app but you could use the trial before .
http://m.pro.getjar.com
😊 Regards jApi NL
No. No. No. I'm interested in the application (patch) to change the length and spacing as a text message or call comes.
For example, SMS Vibration = 1 second vibration, 0.5 seconds off, 1 second of vibration, 0.5 seconds off.
And I want to change the vibration = 0.5 seconds vibration, 1 second off, 0.5 seconds vibration, 1 second off.
Is there something wrong with that application ? They claim 37 different settings . And you can install the free trial to find out if one of the settings suits your needs .
😊 Regards jApi NL
Hall effect devices will sense magnetic fields. Their output can be on/off or proportional to the magnetic field. The frequency of a wave is determined by the source, thus once generated the frequency of a wave never changes. The wavelength however, can be changed by altering the velocity as you say. However, the tuning fork will still produce soundwaves at its natural frequency, this said, you could increase the wavelength of the wave by making it travel through a less dense medium..
This application has 37 modes, but how set modes vibrate when come SMS?
Sorry, My English is not perfect. 😊
According to my self or as per i know you can go thought your cell settings and than vibration settings and select on option. Thats the only way.
