cameraproblems N79 nokia
2 replies · 5,735 views · Started 03 May 2010
hi,
bought a nokia n79 about 4 months ago, everything worked fine. camera was awesome @ the first time but now (since a few days ago) it suddenly doesnt work anymore (whenever i take off the camera protection cover nothing changes @ the screen). be4 whenver i took off the cover it started working as a camera. on the beginning i could make both video and photos but now i take off the cover and the camera doesnt react. i have installed the newest software but still nothing.....what can i do?
Did you check the Menu ? Go to Home/Menu > Applications > Camera , or a sequence similar to this . Click it and it should work , with Cover open !!
In Options there is a possibility to move the Camera Icon to a more convenient place .
😊 Regards jApi NL
Did you check your camera settings surely there's somethig because as per problem may be there is software problem. You said that you installing advanced software but may be that not supported in your cell.
