At every turn in the mobile world, you see online services being launched, and applications that tie into existing services. Examine the top ten things that a typical iPhone or Android phone owner does and I'd bet that over half (if not 7 or 8) involved Internet access. The number's arguably lower in the Symbian world (more built-in/local functionality), but the trend is clear - software and service designers are assuming that mobile Internet access is a given. But what happens when the (signal) bars' run out?
For everything else that fails, there is Garmin Mobile XT
i can use Garmin Mobile XT navigate wherever i want to go in an offline mode.
Now try to beat that using Ovi maps. 😃
I agree about Ovi Maps. It takes about 10 minutes to find the satellites on my E71 if I'm driving and never finds them if I'm walking. I don't mind paying a few cents of data roaming charges when I'm out of the country, which is where I really need maps, but what am I supposed to do until it finds the satellites? Drive around in circles?
Google Maps finds the satellites immediately, even indoors, but then it doesn't have spoken driving directions.
Hmmmmm.
On the Google Documents (& Mail for that matter) point, there's one trick you can do to still use your browser. If you use Opera, you can just get to the data you want, before you leave home, and use the 'Save Page' function. Then you can still use your browser to look up what you want, but you can do it offline.
One note regarding Evernote, on the iPhone, (and possibly Android) you can star an item as a favourite, which then stores a local copy for use offline, not sure if the Symbian widget does this yet, at least I couldn't find the option.
Hang on, I thought that Garmin Mobile used Google for it's local services serach? I am pretty sure that that cannot be cached. Right? Or what am I missing?
I think we could debate the relative strengths of GPS signal lock and Ovi Maps Search functions till the cows come home, go out and come back home again but for me, with my N85 running running Ovi Maps 3.01 it finds a GPS signal in my house, even sitting 2.5m's from a window and outside gets a lock in under 10 seconds. Under 20 if if it is the first time I have needed GPS since my once fortnightly restart, and has only once failed to find an address on the phone itself, but the full Web based client found it no problems.
As for signal, well here I have no 3G, but the 2G is excellent and extends to just about the farthest corners of the area, and I'm talking about places that maybe only see a one or two humans every other year! The nearest 3G signal is about 60Km's away. As it stands right now. By the end of the summer the two biggest MNO's in the country will have this area covered by 3G. As for the "remoteness" of this area. Well, 1,178 people cover a land area of 6,439 square kilometres (that's population density is 0.18 inhabitants per square kilometre)! So while I can't fault any of Steve's recommendations, especially the one about the hand over between online and offline, I really do think that this should be a rant at the the operators. Yes the developers could make things easier, but then if you don't have a signal of any sort, then you can't even call someone! And they are, after all, mobile phones!
They are not just phones though, they have many functions. And Google Maps is the prime example of something that becomes useless 10 minutes from home because it just becomes a grey screen. I simply can't use it, Ovi Maps is the only option. No signal = no google. Crap.
The article touches upon a good point - from the side of the developers there certainly seem to be an increased tendency to rely on "the cloud" and thus a constant connection. This is not just a phone thing, but goes for PC's too. If the network is available it is smart, but it can get pretty annoying when not.
As far as mapping goes, I have been using Ovimap with voice guided navigation many times in off-line mode - more specifically with an X6 without a SIM card in it. It works excellent and I dont think that it takes much longer for the GPS to lock in on the satelites than usual, but of course searching for stuff is not possible. The trick is to ensure that you have all your possible navigation targets saved as favourites - then just select one and off you go. In this respect Nokia deserves kudos for having designed a much more reliable system than Google...
Really good article Steve 😊
However I find the opposite, I'm with o2 (Known to be not so great with signal?) and I barely ever lose my 3G with my 3GS. Oddly the places in which I do lose 3G (Amd revert to Edge, so not quote 2G) is in my local cinema and the place in which I work (Only some areas, toilets etc).
In fact Google maps has helped me A LOT more times than it has been a nusiance, recently directing me and my Girlfriends family around London - back to our hotel 😊
Taking in the above I completely disagree with this article, maybe it's because I use an iPhone and like you say, 80% of what I do is online but I couldn't live without online services, case in point check out an iPhone game called "Pocket Legends" an online MMO (over Edge, 3G and Wifi might I add) that just wouldn't be possible with your crippled outlook Imo 😊
I feel your pain.
O2 signal in Sunderland is dire in some area's... city centre locations with no signal at all. Worst of all, no signal at the Stadium Of Light on a match day.. meaning zero tweeting before, during or after the match (until i get back to the pub).
@Fred* with regards to your GPS fix on the E71. I had similar problems but solved it by changing my positioning settings (Settings > General > Positioning). Ensure you have the "Assisted GPS" positioning method enabled and also ensure that the positioning server is correct. This should be set to "supl.nokia.com" ... if it has http:// in front (which mine did) then remove it. I get fixed within seconds rather than minutes now
satellite comms.. anyone know of a cellular phone which in normal mode will use a typical carrier and when "the bars run out" switches to satellite mode?
Not me.
Google Maps doesn't find the satellites faster. The GPS is the same no matter what application you use. It's just that Google Maps is using cell towers (and WLAN?) for initial positioning, until a clear satellite signal is available. The latest beta version of Ovi Maps (available for download from betalabs) ads the WLAN positioning, so at least in cities you (could) have almost instant initial positioning. Even indoor. Of course it doesn't work without network signal (it needs data).
All GPS devices (including Garmin, Tomtom) have problems acquiring signal satellites if not regularly used. Usually it can take up to 1 min in perfect conditions with clear sky in a stationary position. If you're driving it can take up to 10 min or more until they get a satellite fix. Also keep in mind that when you start the GPS it will try to locate you at the last known position. If that was a month ago and hundreds of km/miles away, it will need some time to figure it all out. As Steve has written many times use AGPS, WLAN, cell tower positioning whenever is possible (data traffic is minimal and you get almost instant fix).
@Fred* Driving in circles won't do any good. Better stop if possible. It might be that you stop for 1 minute or drive for 10. Better start the GPS before driving. Anyway, you should not operate the GPS device while driving.
Thanks, Jowls, yes, a great tip and something I do almost without thinking, i.e. plan my itinerary and put in everything as favourite 'Places' in Ovi Maps ahead of time 8-)
"Great idea, you'll never have to worry about backing up - but you'll also not be able to retrieve any of the data when you can't get offline, possibly when you need it most."
You meant "online" , may be typo there?
Can I just say Ovi Maps works absolutely fine without a data connection or even SIM in the phone? GPS fix takes a little longer in places it hasn't been before, sure, but only a minute or two. And postcode lookup (not just street name) is fine too, as are POIs.
This article also applies where there is a data signal but you don't want to use it - i.e. while roaming abroad with very expensive data rates. This is why Google Maps and Google Nav are effectively useless, and no real competitor to Ovi Maps Nav - they rely critically on a data connection.
There also needs to be a lot more work on caching web data for browsing later offline, you simply can't pre-download websites on phones at the moment, for when the data connection is flaky or non existent (e.g. on train, plane, countryside etc). This is a crucial development that needs to happen to my mind.
Unregistered wrote:There also needs to be a lot more work on caching web data for browsing later offline, you simply can't pre-download websites on phones at the moment, for when the data connection is flaky or non existent (e.g. on train, plane, countryside etc). This is a crucial development that needs to happen to my mind.
That's surprising because my Psion 12 years ago used to do that. There was an app that I could tell how deep to follow links and it would go an cache all the pages and then sideload them into the PSion.
That would have been so useful yesterday on my train journey; tunnel tunnel tunnel cutting tunnel cutting no signal no signal no signal.
...but you're all missing the most important issue with this article.
"But what happens when the (signal) bars' run out?"
What the merry intercourse is an apostrophe doing there?
Who cares about network coverage when you've got breathtaking scenery like that?
Seriously, I live and commute between the two worst countries on the planet for signal coverage and you will never find me complaining.
@davey_lad
Thanks for the suggestion, but my menus don't seem to be the same as yours. I open Ovi Maps (v3.03), highlight any of the options (My position, Find places, etc.), click on Options, Settings, Internet, and the first item is "Connection". I have this set to "Online" and then the "Default access point" is my cell phone (and data) provider. I don't see a place to set it to "supl.nokia.com".
What map program are you using?
@davey_lad
From an American perspective, this is somewhat solved by CDMA wireless technology. Sure, GSM is the global standard, and I'm even currently GSM (AT&T), but back when I was with Verizon Wireless (CDMA carrier), I could get a signal pretty much anywhere in the U.S.
And I mean anywhere.
I remember a camping trip with my buddies around 2006-2007; we were out in the middle of nowhere in upstate New York. Those with GSM cell phones at the time could barely receive a bar of signal. My Verizon phone had no problem; I had a full signal lock while trekking through woods.
And most of the latest Android phones here, are on the two CDMA carriers (Verizon and Sprint).
Jimmy1 wrote:From an American perspective, this is somewhat solved by CDMA wireless technology. Sure, GSM is the global standard, and I'm even currently GSM (AT&T), but back when I was with Verizon Wireless (CDMA carrier), I could get a signal pretty much anywhere in the U.S.And I mean anywhere.
LOL!!! Hilarious. I have heard some wierd stuff but that is a complete joke!
Massive huge big holes in CDMA USA coverage in my experience, and by the coverage map on Verizon's own website.
Why do people look stupid by making this stuff up when it's so easy to disprove?
Unregistered wrote:LOL!!! Hilarious. I have heard some wierd stuff but that is a complete joke!Massive huge big holes in CDMA USA coverage in my experience, and by the coverage map on Verizon's own website.
Uh, that's a true story.
Also, a true story: around Long Island, NY, GSM just recently caught up in coverage. Years ago, you could barely get a signal at Jones Beach or out in the Hamptons. CDMA never had a problem. My only problems with it is that you can't get unlocked devices to use on CDMA, and Verizon is ass-chapping expensive with fees.
Jimmy1 wrote:Uh, that's a true story. Also, a true story: around Long Island, NY, GSM just recently caught up in coverage. Years ago, you could barely get a signal at Jones Beach or out in the Hamptons. CDMA never had a problem. My only problems with it is that you can't get unlocked devices to use on CDMA, and Verizon is ass-chapping expensive with fees.
So a single anecdote is conclusive then? I've been in situations where the reverse situation occured, where both had good signals and also where neither had good signals.
I'm pleased that you have found locations where Verizon have good coverage.
That will make all the difference to the guy in the white areas on their coverage map.
On a slightly related note, I've had major problems with the Three UK network on my N97. Three piggy-backs on the Orange network for GSM coverage when it has no 3G coverage. This often means calls are dropped and/or coverage lost when in the grey zones between cell sites.
It also means apps like Opera Mini, which can only use one internet connection at once (i.e Three - it can't choose the 'internet' destination), cannot connect to the internet while the phone is piggy-backing on Orange. The phone acts like it's using Three, but it doesn't work the same. So whenever I'm travelling, especially on a train, and have no 3G coverage but plenty of GSM coverage, I cannot use Opera Mini. Bah to Three.
In fairness, Ovi Maps also has an offline mode which I always default in to.
@jamessmith01
I have not seen this problem on any of my Nokias on "three" going back to a 7600 via 6680, N70, 6210c and currently E75. They have all fallen back to GPRS on either O2 (in olden times) or Orange I even see the E (I assume EDGE) on the E75 sometimes. Handing off voice calls from UMTS to GSM always drops the call and google maps seems prone to not re-establishing the connection if it does a handover and needs a stop and start.
@Davey_lad good tip wondered why my GPS had gone crap recently. Seems a factory settings reset deleted my server settings
@Fred
On E75 (S60 V3 FP2) in <control panel><settings><general><positioning><positioning server> you should find the place to put the supl.nokia.com address in.
That setting is not in Ovi Maps, but in Tools>Settings>General>Positioning>Positioning Server and then the 3rd item Server Address. The phone does the communicating with the server rather than the Map programme.
Opened this article hoping it would be a little deeper given Steve's preference for comparisons/lists.
Having owned and used Palm, WinMo, Psion/Symbian, Android and Apple devices over the last 13+ years in stand alone mode or on CDMA/GSM networks while traveling, the offline experience is pretty important for me personally.
Offline, WinMo has been my favorite for most of that time.
The tremendous ability of devices these days - most especially cam/video/GPS with the ability to drive quality video output while connected to keyboards and game controllers means the offline experience may be more important now than ever.
The more effective a unit is at operating SIM-less stand alone or connected by WiFi, the desirable.
I have a simple test: prior to installing the SIM the unit is booted and stretched out. Setting aside the occasional knee jerk response to never register any device online, if necessary, this is done then the flight mode enabled and/or the SIM removed.
If the unit is fully functional less carrier connectivity it passes.
If not, adios.
@animal63
Please can you clarify what you meant - have you successfully used Opera Mini on the three network while it's piggy-backing?
