N97 Calendar Entry
3 replies · 5,400 views · Started 06 May 2010
Hi...
Can someone tell me if you are having the same issue with calendar entries ??
1. When i create a new calendar entry automatically the alarm is by default set OFF.
2. In the same scenario, if i select repeat the date that appears automatically is 12/30/2100.
Thanks in advance...
That's normal behaviour my friend... that means alarm is off until you turn it on and the repete by default is "forever"
Thanks, but this is weird. I changed my E71 and these features was included by default.
Once again THANKS...
