Debranding but keeping the T9?
2 replies · 6,574 views · Started 08 May 2010
Hello,
Looked all over the Internet for a solution (if there is any) to this problem of mine. Also searched here on the forums, but I didn't find anything similar to what I looked for.
So I'll get straight to the question; I have a Nokia N95 8GB, the Scandinavian version. However, I want to debrand it to the EURO 2 so I can get the phone language in Polish. BUT, I want to keep the T9 settings, i.e. still have Swedish as writing language (or what it is called in English haha).
Is this somehow possible to get? Appreciate any help I can get!
Thanks,
Adam
Don't know the answer to that, but would have though that if once you have debranded it to Euro 2 and the language is NOT there, could you not change the product code again to get it back to the desired language?
Or is it the case that certain Product codes only support certain languages? Would have though that Euro codes would support most European languages?
Thanks for the answer, I didn't debrand it and check because if my desired language wouldn't be there, it would be bothersome to debrand it back to Scandinavian haha.
So you think that the EURO codes would include all languages? I'll check it out.
